ROLARACER Posted March 26, 2012 Report Posted March 26, 2012 WE HAVE A 4AGE ADJUSTABLE CAM WHEELS TWIN 40MM DELORTTO CARDS ,AND WANT TO RUN AN IGNITION IGNITER AND MODULE SEPARATE TO THE CUMPUTER WHICH PREVIOUSLY RAN THE FUEL INJECTION, CAN ANYONE RECCOMEND PARTS REQUIRED AND PREFERRED BRAND Quote
Subaru_kid Posted April 19, 2012 Report Posted April 19, 2012 I believe you can modify the dizzy from the 4AC and maybe the 4K to suit which both run on carbs. But i could be wrong, last time i looked at doing a carby setup was a few years ago Quote
corollaart Posted April 19, 2012 Report Posted April 19, 2012 Hyper pak work ok the guy can be a pain to deal with at times (ebay).Also can use a 4k electronic disy ,but you have to use a spacer and 4a drive gear. Not the best, more a povity option but works ok. They is also msd ignitions.(not clear on these)what you need as far as part numbers etc. Quote
