Trent-KE30 Posted January 10, 2006 Report Posted January 10, 2006 Hey guys, i'am trying to get my KE55 roadworthy, couple of little things that need to be done, - First of all is the fuel gauge, it doesn't move at all, i have checked the gauge itself and tested my KE30 one in there and it still doesn't work, i then checked the sender unit and took off the plug going to it, cleaned it and still won't work, can anyone else think of anything else? Lastly i took off some of the emission shit, will they knock that back for not being there? Thanks Trent Quote
love ke70 Posted January 11, 2006 Report Posted January 11, 2006 have u traced all the wires to make sure they are all connected? just gets lots of spagetti and string it around with a few vsv's and one way valves and all ends plugged into each other, theyll have no dramas with that :harhar: just make sure it looks like its all there, most of them don't know what or how much should be there anyway, goodluck mate and why do u have to have a fuel gauge? Quote
Trent-KE30 Posted January 13, 2006 Author Report Posted January 13, 2006 Yeah thanks about that emission info, Someone else told me about the fuel gauge not being a problem, might just leave it and carry a fuel drum in the back :harhar: Thanks Quote
love ke70 Posted January 13, 2006 Report Posted January 13, 2006 no worries, and out of interest why did u pull the emissions stuff off? mine runs happier with it on, and most of it is only for cold start anyway Quote
Trent-KE30 Posted January 13, 2006 Author Report Posted January 13, 2006 Cause i got another 4K with it all blocked up ball bearings and shit and it seems to runs alot better Quote
love ke70 Posted January 13, 2006 Report Posted January 13, 2006 hmm, i spent a coupla hours setting mine up properly according to the diagram and it smoothed her out alot and you may find the difference between the 2 motors is not related to the emissions crap, i have 2 and one is alot better than the other, most of these motors have done alota k's and it depends on what sorta work has been done to them in this time :harhar: Quote
Trent-KE30 Posted January 14, 2006 Author Report Posted January 14, 2006 Yeah well i think the other 4K may be mildly worked, I have since put all the emission back on the KE55, looks like its wrong oh well looks like its doing something :P Quote
love ke70 Posted January 14, 2006 Report Posted January 14, 2006 lol i have the diagram if u want to do it proper but mines for a ke70, and different to the ke70 vac diagram that teddy put up here one time Quote
Trent-KE30 Posted January 14, 2006 Author Report Posted January 14, 2006 There's a emission diagram on the bonnet i might follow, cheers for the help love-ke70 Quote
love ke70 Posted January 15, 2006 Report Posted January 15, 2006 :P that diagram would be the one, id recomend pulling it off, scanning it and printing out a blown up version you can draw on. and it also means you still have the thing, coz not many cars ahve them anymore Quote
dolzz Posted January 22, 2006 Report Posted January 22, 2006 Hey, yeah just another Question on the fuel guage, On my ke55 the temp an fuel guage isn' workin. The actual needles works upon sending current through both. Apart from the float in the tank being the problem Ive hered that it can be the 10v converter behind the cluster, is this true? Any ideas? Quote
Trent-KE30 Posted January 23, 2006 Author Report Posted January 23, 2006 Sounds like my problem, i'am pretty sure mine was working when i got the car, anyway I'm getting another KE55 cluster soon, hope that was the problem, Dolzz check the temperature guage clip thingy near the thermostat, they can sometimes come loose, mine was and it seemed to have cured it now, Let me know how you go, Trent Quote
JiP Posted January 23, 2006 Report Posted January 23, 2006 Dolz, sounds like you've got the same problem i've got on my KE30. I got my whole speedo fron the wreckers. It may have been from a KE55. Either way i can't check, I was there today and the was crushed. I made my current speedo out of that one and the original cause the original's speedo needle kept slipping and telling the wrong speed and my clock was broken. Does your Temp Guage and Fuel Guage kick in every now and then?? I find its the lagre, white, round connection behind bothe guages. I usually stick my arm under the dash and give it a jiggle while driving and it kicks in. I'm looking at hopefully Getting a third Speedo when i get my new dash recovered. Anyway, Good luck. JiP_01 ~Here's a pic of what my speedo was like~ Quote
love ke70 Posted January 23, 2006 Report Posted January 23, 2006 thats a very purdy speedo unit, do they all look like that or has yours been tidied up somewhat? Quote
Rolla__Boy Posted January 23, 2006 Report Posted January 23, 2006 Mine looked like that....I'll find a pic tomorrow of what it looks like now Quote
