TE278U Posted March 21, 2012 Report Posted March 21, 2012 http://www.rollaclub.com/board/topic/34832-wtd-67-ke10-parts-updated/page__gopid__591727#entry591727 ;) Quote
Jono.C Posted March 21, 2012 Author Report Posted March 21, 2012 (edited) Cheers for the though TE278U But it's from 2009 and i think posting doors would cost a fair bit :blinks: That's up next Stu :jamie: haha Some more pics :) Put the front number plate back on properly Dished Piston 4k Most awesome jack i've seen! Un-80's-d the boot haha Drained the boot of it's lake Edited March 21, 2012 by Jono.C Quote
parrot Posted March 21, 2012 Report Posted March 21, 2012 No way, the shagpile HAS to go back in after you hit it with a high pressure washer, although it will probably disintegrate. And make sure you change the bit of fuel line from the fuel pump! Quote
67Rolla-Ken Posted March 21, 2012 Report Posted March 21, 2012 ...and I want to get that jack sticker remade!! Quote
Jono.C Posted March 21, 2012 Author Report Posted March 21, 2012 ^ I saw it and pulled a mad grin! Too scared to use it now :lolcry: Quote
67Rolla-Ken Posted March 22, 2012 Report Posted March 22, 2012 I really would like to get that remade. Along with all the engine bay ones (air filter housing, rocker cover etc)! Quote
Taz_Rx Posted March 22, 2012 Report Posted March 22, 2012 (edited) Must be a 4ku. Apparently the go better than the kc! edit - yeah they use the longer spark plugs as pictured. Edited March 22, 2012 by Taz_Rx Quote
Jono.C Posted March 22, 2012 Author Report Posted March 22, 2012 What are the advantages or a 4ku? Had a bit of a read around but the only thing i could stem was they have stronger exhaust valves Quote
JJT036 Posted March 22, 2012 Report Posted March 22, 2012 A few extra kW/HP than a standard 4K, and dished pistons, as mentioned above? Quote
Jono.C Posted March 22, 2012 Author Report Posted March 22, 2012 I gathered the dished pistons, same as my 5k. Oooooh wikipedia reakons it has 55kw up from the stock 41kw. :laff: My ke70 5 speed will do wonders for this car Quote
SLW42 Posted March 22, 2012 Report Posted March 22, 2012 Won't it also force the shifter to be basically where your sitting too? Quote
Jono.C Posted March 22, 2012 Author Report Posted March 22, 2012 Nope, not too bad, I've got a modded shifter for it anyway Quote
SLW42 Posted March 23, 2012 Report Posted March 23, 2012 Like chopped within an inch of its life modded or done properly Quote
Jono.C Posted March 23, 2012 Author Report Posted March 23, 2012 Pulled it into the 2 pieces, Bent it so it's vertical not bent, Chopped the black part and welded tube around it so it's back together but further forward and 3" shorter Quote
Jono.C Posted March 23, 2012 Author Report Posted March 23, 2012 (edited) Haven't done too much too this. Due to the weather mostly but also waiting for parts and to be semi-financial to carry out some work on this. Working on the interior a bit. Filled in the hole in the drivers door for the late model door handle, looks much cleaner now. Also removed both tape players and had a facepalm, it was the dodgiest wiring i've even seen, so spent a fair while tidying it all up. Then i was left with a hole in my dash, as the trim to cover it is both rare and overpriced i set about fixing it myself. Yes, it's carbon wrapped. Lol. Only thing i had to cover it, will be getting some satin black vinyl wrap this weekend to recover, and put a ke10 guard badge on it. Tape player Hacked radio panel :( Result Edited March 23, 2012 by Jono.C Quote
