azzy_10 Posted March 18, 2012 Report Posted March 18, 2012 (edited) looking at doing electronic fuel pump set up instead of the mechanical on my ke30 3k And started to look up some pumps last night Any ideas and help please Edited March 18, 2012 by azzy_10 Quote
parrot Posted March 18, 2012 Report Posted March 18, 2012 Make sure it is low pressure only, 4 psi max. Think about how you wire it so it turns off if the engine stops without having to turn the key off, bearing in mind you should locate it in the boot near the tank. Rubber mount it. I had a facet pump years ago and even rubber mounted it was pretty noisy. Remember you will need a fuel pump blanking plate. When you find one, tell me where as I need one too. Quote
coln72 Posted March 18, 2012 Report Posted March 18, 2012 Used to run Facets as I used to get them for free. Noisy but reliable. Had the on in the racer wired up so that if the motor lost oil pressure, it would cut the fuel. don't ask me how it was done now though. Quote
azzy_10 Posted March 18, 2012 Author Report Posted March 18, 2012 (edited) looking ats facet fuel pumps now from the usa Purolator Facet 60SV Electronic Fuel Pump 2.75-4PSI! Made in the USA Edited March 18, 2012 by azzy_10 Quote
JJT036 Posted March 18, 2012 Report Posted March 18, 2012 bought one today $60 bucks at autobarn its a fedtro brand & works a treet with a holly 180 Quote
azzy_10 Posted March 18, 2012 Author Report Posted March 18, 2012 what type of fuel pump and I'm running stock engine no mods Quote
JJT036 Posted March 18, 2012 Report Posted March 18, 2012 "fedtro brand" part #40105 distributed by aust auto parts 03 98450800 they will tell you a stockist near you Quote
azzy_10 Posted March 18, 2012 Author Report Posted March 18, 2012 whats the gallon per hour or liters per hour Quote
azzy_10 Posted March 18, 2012 Author Report Posted March 18, 2012 have you set that all up yet pics please and isnt that to much gal per hour Quote
19914afc Posted March 18, 2012 Report Posted March 18, 2012 Why do you need an electric one? Or is your mechanical one stuffed and just seeing if the price is around the same for an electric setup? Quote
azzy_10 Posted March 19, 2012 Author Report Posted March 19, 2012 yeah i did my oil and filter ages ago and the level is rising in the sump and can't be bothere doing mechanical Quote
philbey Posted March 19, 2012 Report Posted March 19, 2012 The level is rising in the sump? As in you've busted the fuel pump diaphragm and filling the block with fuel? Seriously though, facets are a pain in the arse noisy piece of shit. It'll be a cold day in hell before I install one over a mech pump. Quote
BUZ440 Posted March 20, 2012 Report Posted March 20, 2012 Source power from the tail lights so when you have your parkers on, Can work like a turbo timer also, turn it off and let it starve the engine of fuel, haha Quote
ke70dave Posted March 20, 2012 Report Posted March 20, 2012 (edited) i dunno if fuel is a good lubricator, you might not have an engine to supply fuel to if you keep that up! i see no reason for an electric one, just get a new mech one? edit: the oil pressure idea is nifty, but you would need to hook it up so that it activated on "start" on the key. so it went when you pressed start, kept going when you had oil pressure, but turned off with no oil pressure or no start. Edited March 20, 2012 by ke70dave Quote
