I quite love this thing, keen as hell to see it with some boost, my cousing had a gt30 and it was nuts, was a little laggy but he could stab the throttle rolling at 70kmh and it would light them up
Started assembling things on the car. put the turbo, manifold and lines on, also put the fuel rail and injectors on.
also took the intake off and spent some time changing the loom to hide it a bit more
so after seeing the price of a genuine garrett v band flange i decided to buy a $30 v band kit and turn it down to the right size and made up a dump pipe
got everything together now just waiting on a waste gate. plugged off the hole and had a bit of a play with the laptop and got it idling.
splitfires showed up today so put them on, just waiting on a wastegate now
couple of before and afters
Edited by Ridemx21
Got the car on the dyno last night but quickly ran into some
Fuel issues before we got much done. So now i got some 1700cc injectors,
Ordered a holley 12-1400 fuel pump and am sorting out some 1/2 inch hardlines and a better surge tank
Upped the fuel system
1700cc injectors
Holley dominator 1400 pump
Aeroflow surge tank
1/2inch feed 3/8 return
Once it got a bit of fuel back into it the power figures got a bit more realistic too
Pretty damm stunning! It started off as such a cheap and simple conversion too...
I also reckon white wheels, the black wheels are just so 'high-school' now.
.. when are you going to be happy enough with it to just drive it around? :laff:
it gets driven daily, my only car at the moment
The heavy duty clutch i was running started to give up so i bought a hhdb exedy clutch and picked up a blown rb25 box so have a play with while it was apart, seem too all fit in pretty well so ill look at rebuilding the box and replacing the 20 box in the future
put my new clutch in doesn't feel the best with a very high release point but I'm told these clutches can do weird things for the first 1000kms while they bed in so ill see how it goes
also had another couple of rockers break on me
had some hand brake issues so decided to strip the rear callipers down and do a quick clean and rebuild
and also found that the crank breather between the bottom end and the rocker cover is suppose to have a restricter in it so i pulled it out of the original pipe and put it in the new one
