THUNDApanda Posted March 5, 2012 Report Posted March 5, 2012 hi all bought a rolla bout a week ago was only going to use it as a daily but that changed pretty quick so now I'm building a budget drift car it kinda has alotta rust in it Quote
ke70dave Posted March 5, 2012 Report Posted March 5, 2012 I see the weight reduction is well on its way! Quote
THUNDApanda Posted March 5, 2012 Author Report Posted March 5, 2012 thats true I'm sheding the pounds as fast as possible thanks for the win but its a 4k-c not 4ag i worked all yesterday to tear out as much as possible started at 7 finished at 9 there was a complete dash here before the next thing to go is the whole a/c unit all but one seat gone, bumpers removed, tore out all unless wiring Quote
BlueKsev Posted March 5, 2012 Report Posted March 5, 2012 Just think of the rust as more weight reduction :wink: So what motor are you looking at to put in?? It all depends on how much you want to spend on it i guess Quote
Willis Posted March 5, 2012 Report Posted March 5, 2012 thats true I'm sheding the pounds as fast as possible thanks for the win but its a 4k-c not 4ag Yeah, I know... Quote
THUNDApanda Posted March 5, 2012 Author Report Posted March 5, 2012 Just think of the rust as more weight reduction :wink: So what motor are you looking at to put in?? It all depends on how much you want to spend on it i guess rust is lighter then carbon fiber :lolcry: was thinking bout putting a evo engine in it if i can get 1 cheap enough, though I'm getting some input from others bout an engine convertion i just need something that will develope at least 180rwkw anything over that will do :rock: Quote
Willis Posted March 5, 2012 Report Posted March 5, 2012 rust is lighter then carbon fiber :lolcry: was thinking bout putting a evo engine in it if i can get 1 cheap enough, though I'm getting some input from others bout an engine convertion i just need something that will develope at least 180rwkw anything over that will do :rock: Can get 180rwkw out of a 4AGTE. Would be a handful in a KE70. Quote
SLW42 Posted March 5, 2012 Report Posted March 5, 2012 A cammed 5k with a Webber ported head and full exhaust should make for a cheap drifter for a tight track, the rest will be upto speed and how big your balls are, Btw how big is your budget..... you could get away with a 4age conversion doing most of the stuff yourself, except wiring unless your an auto sparky for $5-$6,000 then, once thats running fine it will be a 'budget' drifter Quote
THUNDApanda Posted March 5, 2012 Author Report Posted March 5, 2012 my budget is real small so I'm kinda trolling wreckers for cheap/free parts but i can spend bout 4-5000 on it at most i was just thinking of getting a half-cut and useing everything off that but I'm just a bit shy on the price of them thinking bout maybe a sw20 or ca18det if i can get them for a decent price Quote
SLW42 Posted March 5, 2012 Report Posted March 5, 2012 I have picked up many ca's for like $100 haha, so you can get them cheap enough, you just gotta look around for awhile and make sure you make your mind up on a definate engine. A Ca or Sr half cut would be good for a conversion and you could sell a lot of things and make some cash back, the motor part won't be that hard cause a million people have put sr's and ca's into keto's and there is a heap of info on this site to help, but you also have to look at brakes then suspension, tailshaft, fuel system for a ca18det conversion your looking at about $10,000 doing most of it yourself and finding shit cheap as chips, your much better of doing a 4age conversion cause they are a lot easier to do and can be turbo'd with minimal hassles Quote
19914afc Posted March 5, 2012 Report Posted March 5, 2012 Well lets see so far what ive sold from the T18 the shell would have cost me $1000 (very good shell for the age) Suspension and brakes would have cost about 3k (all suspension inc swaybars ect) wheels about $800 Engine (1UZFE V8) was FREE! but only because I bought a whole car and parted it out took alot of time to end up getting the engine for free Gearbox setup will end up being about 2.5K (this engine never came out manual and requires custom parts) Bigger diff $500 Paint and panel work - $200 Miscellaneous - 1k So that is a basic rundown of what it has cost me so far and that probably not all of it but already up to about 10K and that is only because every single thing I have done and can do myself, so if you need to get something welded it will cost even more, cars are not a cheap hobby. I would recommend buying one that has a 4age in it or something can pick them up pretty cheap, because that rust looks pretty bad unless you got the car for free? Quote
SLW42 Posted March 5, 2012 Report Posted March 5, 2012 Once again, 4AG = win? Not necessarily win..... But will fit his budget better hahaha and they can always be modified to run boost later down the track Quote
Willis Posted March 5, 2012 Report Posted March 5, 2012 Not necessarily win..... But will fit his budget better hahaha and they can always be modified to run boost later down the track Sooooooooo.......Win?? Haha. Quote
