Car up.
Wheel off.
LCA out.
balljoint circlip off.
press old balljoint out.
press new one in.
put back together.
cheers ! any special tool needed to press in ?or a g clamp ect do ? o and what kind of grease for the joints?
Edited by drewsith
Now this may not be the 'proper' way to do it. But it worked for me. Belt the old one out with a hammer. A copper mallet etc.
To get the new one in without a press, I removed the control arm and very carefully used a vice to press the ball joint in. It may tend to skew sideways as it goes in, but you can then 'flip' it over in the vice and counter the sideways movement. No problems.
You'll need somehting to hold hte LCa in the correct position while pressing. A really big socket, or an old bearing race should do it.
THe balljoints should come with grease in a little packet. or already in the balljoint. Or its just Moly grease.
