ollii Posted February 13, 2012 Report Posted February 13, 2012 as u may have geussed by the common theme of my threads i have alot of ke70 parts lying around and i also have a ke10. so has anyone converted a ke70 coil spring diff to fit a leaf sprung ke10? (ie fit leaf springs to ke70diff?) if i do this will i be able to run a standard ke70 tailshaft between a 5k and 5 speed? and most importantly is it worth it? the main reasons why i want to do it is. its already locked. its free. i already have it. and the different PCD Quote
Willis Posted February 13, 2012 Report Posted February 13, 2012 (edited) If you're going to the trouble of putting a different diff in, you may aswell make it worth it. Hilux, T series or whatever. Something you can get an LSD for. The KE10's diff should withstand a 5k. But if you really want to do it then go for it. Edited February 13, 2012 by willis Quote
Redwarf Posted February 13, 2012 Report Posted February 13, 2012 Quote . so has anyone converted a ke70 coil spring diff to fit a leaf sprung ke10? (ie fit leaf springs to ke70diff?) There's no benifit. It'll have to be modified to take leaf spring, and it'll be too wide, therefore it'll have to be shortened. Quote if i do this will i be able to run a standard ke70 tailshaft between a 5k and 5 speed? No. Quote and most importantly is it worth it? No. Quote the main reasons why i want to do it is. its already locked. If you want to die at an early age, this is a good way to do it. Quote its free. i already have it. and the different PCD Just because you can doesn't mean you should. Quote
ollii Posted February 13, 2012 Author Report Posted February 13, 2012 Haha ok I can take a hint... So i should go 5k 5 speed standard diff for now. What's the best way to link these? I'm pretty sure it's ke70 5speed.( shifter at rear) Quote
Redwarf Posted February 13, 2012 Report Posted February 13, 2012 (edited) KE70 shifter is going to be in the wrong place, and will probably appear through the floor at about the handbrake. Edited February 13, 2012 by Redwarf Quote
Jono.C Posted February 13, 2012 Report Posted February 13, 2012 (edited) :y: Edited February 13, 2012 by Jono.C Quote
ollii Posted February 13, 2012 Author Report Posted February 13, 2012 Oh what a shame will have to make a hydro handbrake .... Damn :( Quote
Jono.C Posted February 13, 2012 Report Posted February 13, 2012 ..? Lol. It'd be fine once the hand Brakes down. Quote
