Can it be done?
I have a ke70 crossmember with brakes and stuts and cut springs. Will this fit in the front my Ke10 or is it easier to covert to the drums as per the FAQ section? And does anyone have some stockies for sale so I can move this thing around abit easier? I'm located in the hunter.
Hey man. I'm converting my ke10 to rack and pinion with a ke70 crossmember. No, It doesn't bolt in. I've chopped and welded my crossmember and redrilled and braced it to bolt in. Still have to get an engineer to look it over and see what he says.
Also need shortened lca's etc, it's a lot of mucking around and all custom.
You're better off just converting yours to ke20 disk brakes and ke20 springs
