  • 4 weeks later...
haven't had much time,i will fit carpet back in as i fitted a new loom and removed and refitted the dash,wos fun job lol.
now its cooler i can get stuck into it more often have to change the linkage abit and make somethink up for the throttle cable but shouldn't be too hard.
will post more pics somtime this week.
  • 2 months later...
Buy a throttle linkage kit, good ones allow the correct travel for the pedal/carb by using a ratio lever
and also have strong independant return spring, don't use the butterfly return spring on its own.
wos a putty i got oil,petrol,and will hold presher upto 1300psi resistant. been using it for years on diffrent things holds up relly well.
wouldnt be able to get the name of it would you?
yeah i have a full link set up with wheels and the rod and stuff sorted out. will post more pics but i have the car for sale on ebay and on hire.um the putty i used its like liquid stell you cut abit off and need it with your fingers and it gets tacky and starts to turn hard. i lost the tube i used so the name i can not remember!! i have even used it to seal up a cracked mag wheel still holds today after 6 munths.on the inside off the mag but yeah look at your hard wear shops few diffrent names long as it can handle heat petrol oil and presher shood be fine?
  • Upvote 1
