  • Replies 151
Hooray for boobies!!!
I mean hooray for toyota, just got the LCA's in and only lose a lil bit of skin doin so, so now I'm happy :)
The only minor hiccup i had was having to scoot around the corner to the local fulcrum supplier to get a new rubber boot. $15 bucks is a hellova lot to pay but meh just shows how ghey saturday mornings really are hey. Still wishing i had a Nick 55 cent special tho....
Also got an exhaust quote. $350 all up for a 2into1 collector + "sports" exhaust + 18+ inch hotdog + piping and i supply the cat. Seems good to me or he can do it of round $250 with my ebay exxy but he thinks it may have noise issues getting und 90db.
Anywhat... I'm now off to setup these mammoth brakes :P
oh and heres a pic of them wheels i got on hold in japan...look exactly the same cept theyre 15inch x 6.5
Hmm :P
Now that ive had a proper look, i have formulated a plan to get these baby brakes to fit.
If you elongate the holes on both the hub and rotor, they should bolt together. However due to the enormas off set on the stock rotors and even considering the RA disc's being nearly twice as thick there will still be some slack meaning less track than stock. I'm thinking that a 5mm steel plate with the correct holes drilled combined with the elongated hubs and rotors will match perfectly.
Now ill just have to wait till monday to go get them drilled :lolcry:
Note - i can't be f@$ked getting correct measurements just now, maybe later.
Oh, and does anyone want a template once i get mine done? might save youse a lil bit of time if ya go RA60 brakes and rotors like me :)
biggo if you want ive got the shed back now weve ripped the engine out the dirty exa so i can pull mine down and have a look at the way they did it?
but only if you want me to...
yes please
just so i can give the gimps some idea what to do when i dump the lot off at the brake place on monday.
how was the exa :P
okies. ill do so tomorrow.
don't even start about the effing exa. who knew fwd engines were so effing hard to get out.
5 engine mounts i say! 5 WTF!!!
nice flowers hippy boy :P
try :P next time :P .......unless ur into the flowers..which i don't really doubt haaahahah
my brakes look just like that....only rusty :)
