Nathis Posted January 16, 2012 Report Posted January 16, 2012 I have just purchased a corolla with a blacktop 20 valve 4wd , not knowing too much about them I would like to know if anyone might know what might cause a noise I have from I think the engine. It does not sound like a bearing noise more like a growling whirring noise increases with engine revs. It's a little bit hard to explain exactly kind of sound. Quote
ae824ate Posted January 16, 2012 Report Posted January 16, 2012 I have just purchased a corolla with a blacktop 20 valve 4wd , not knowing too much about them I would like to know if anyone might know what might cause a noise I have from I think the engine. It does not sound like a bearing noise more like a growling whirring noise increases with engine revs. It's a little bit hard to explain exactly kind of sound. Ahhh, you mean that funny noise, yeah i know the one. don't know what it is though. What model corolla have you got? I am asuming someone has done the 20 valve conversion? If you think its the donk poke your head under the bonnet and give it a rev? If you want help, go into a bit more detail dude, or maybe throw up a vid if you can. Quote
altezzaclub Posted January 16, 2012 Report Posted January 16, 2012 Unless you're better with words than Shakespeare, you haven't a hope of getting us to imagine the noise you're hearing. The only answer is- throw up a vid if you can. Is it a Tercel? with its three whiny diffs?? Quote
ae824ate Posted January 16, 2012 Report Posted January 16, 2012 Is it a Tercel? with its three whiny diffs?? I had wondered an AE95 perhaps. Id like to see it either way :yes: Quote
terryo Posted January 19, 2012 Report Posted January 19, 2012 it might help if you post your location, then someone local could assist. I'm in Ipswich Qld, and will happily look/listen for free. i fix this stuff all day long Quote
Trev Posted January 20, 2012 Report Posted January 20, 2012 Have a rattle? Sounds like the common 20v vvt solenoid. Quote
MRMOPARMAN Posted January 25, 2012 Report Posted January 25, 2012 Have a rattle? Sounds like the common 20v vvt solenoid. yep, very common problem. sounds likely it will be this. Quote
GJM85 Posted January 26, 2012 Report Posted January 26, 2012 a strange growling noise that increases with revs? coming from the engine? probably the quad throttle bodies doing what they do best... Quote
