Everyone will say its not worth the money spent bla bla 4age is king bla bla , but there was a very nice supercharger 4ac ke70 in the rides thread and I thought that was impressive !
Hmmmm,
Does any one know of weber manifolds for them
Available at any good performance or auto shop. I turbocharged my 4a-c years ago with N13 pulsar injection setup, made a huge difference. Lots of custom handmade shit, and not the most reliable setup for the small power increase. I wouldnt bother again.
Nothing wrong with a 4ac, if the one in the mrs car didn't let go then I would still have one in there, best upgrade is a set of extractors (can be quite costly for them and rare, only set I have seen IRL was a set I had), another carby if you think it is necessary as the one on them is fairly good and give it a good service - plugs, fuel filter, air filter, oil and filter.
Also check out the ignition leads, cap and rotor to make sure they look good, another thing to look at (if you have the standard air filter) is to see if the cold air intake switch is working, when the engine is cold vacuum is applied to the cold air intake valve on the filter intake, the air filter then takes warm air from the hot box on the exhaust to aid in cold starts, when it (the engine) warms up the switch 'should' close up and allow the valve to bring in cool air.
Get the engine up to temp and pull the vacuum hose off and see if it is sucking, if it is then the switch is buggered.
Let me know if you are unsure what I am talking about and I will post up a pic.
Ive only seen one 4ac with twin sidedrafts and it was a custom made manifold for it. I don't think you can get them off the shelf.
Edited by philbey
There is heaps of fun to be had if you willing and willing to spend the time and $$
Extractors are near impossible to get, we started making them before we put in a different motor, for the short term we stripped back the factory manifold removed the butterfly valve and welded it shut.
You can get side draught manifolds in Japan (I still have mine, including matching tuned dellortos etc, well for that matter the whole motor still :D)
We had a blast, got some good power from it overall. It is a job of patience and time (love)
Know heaps about it, so feel free to ask questions, we rallied ours, have a look on youtube.com/jesusrallysport for some videos and check out jesusrallysport.com for pics from the engine build
