Hey. Had a bit of a search with no luck. Just after some exact info on what i need to build a high revvin tough 4k motor. Like cam specs and block prep., lightened bits n pieces too. Cheers
Edited by abel00
More searchy needed... "How to build a tough K motor" would be a start.
Then a few finer details from guys on here.
Then you're into race car prep where people don't like to give secrets away!
So, first and obvious questions-
What are you going to do with it?? Drive it on the roads, drag race it, tarmac race it??
How much can you spend?? If the answer is under $5000 don't waste our time, you don't really want a high-revving tough 4K!
  • Upvote 1
I don't know if youve been told today but your a f$@& head
Edited by abel00
Amazing, you asked the question with very little information and Mr A has given you an answer.
If you don't like the answer, then give more information or F**k off and work it out yourself.
  • Upvote 2
Why? Because he is telling the truth?
Sure, you can build a high revving 4K for under $5,000.
But, by the time you get bored of it, then spend more money on it. Rinse and Repeat. The costs start mounting.
Cheap. Powerful. Reliable. Pick 2.
Abel00 keep the personal abuse in check. As fOr the rest of you, please also keep it civil.
The question has been answered, please take the time to read the link altezzaclub has posted. Don't waste time witha 4 k just get a 5k. You can do what you want for 2-3 grand if you look hard for good deals.
  • Upvote 1
