Hey guys tried to read up on these engines but haven't found any Info on what I'm thinking of doing I'm going to build an engine for my ke30 2door and I have a 3k-c 3k-h and 4k-c at my disposal
Basically ill be doing mild cam upgrade pistons upping the compression and i have redline manifold for a side draft
I'm unsure of 3k small and big ports and have seen people argue about putting them on 4k blocks or weather they are a good combination
I'm not going for earth shattering power I just love the old rollas just want to have some more get up and go
Any info is appreciated cheers
use the 4K...
Then remove the 3K's head get head faced valves cleaned up and slap it on 4K best combo.
Will also know condition of engine to then.
Head clean up on old 8 valve gear is dirt cheap to so ring around you should get a good deal pretty easily.
As for the head to use id go 3K-H I think not sure they don't have the shit house exhaust ports (casting differs on K heads here one is crap other good) so compair them pick the best.
Cheers
Cameron
I was definately going to go the 4k but wasnt sure bout the whole head swap Thing
tried askin my boss cuz he's been working on cars since they had square wheels in the stone age but he diddnt know enough about the k motors he is more of a 253 308 commonwhore kinda guy
Gettin the head cleaned up is no biggy the bloke we use at work is doin it for me dirt cheap
But just out of curiosity why does the 3k head go better on a 4k than the original head
And thnks for the info much appreciated
3K head, 4K block and you'll notice the power increase just from that.
Mild cam and carby and it'll move nicely for an old pushrod motor :)
Keep it simple.
Ok just wasn't sure if the valve train was any different in the heads
Got everything but the carby can't find them on there own every one sells them with the manifold and I already have one
And simple is why I bought a ke no computer bullshit and so easy to work on
