OK, its officially back on the road.
TO do list:
Front lip with CAI pipe hooked up.
rear bumper
tacho wire from coil.
Wire up the voltmeter.
I have 91 in the tank so I need to throw some 98 in then Ill let y'all know what I think.
EDIT: My strut brace doesnt fit over the TB either :(
Edited by B.L.Z.BUB
So basically it's not as fast as you thought it would be?
Gratz Reed!!!
Oh old 91, I think thats the main reason for your average performance. If it's got a knock sensor it's probably pulling all of the timing out of it as it comes onto boost.
OK, my starter motor cable lug came off so it wouldnt start. I stalled at some lights with cops across the road watching and had to fix it in the middle of the intersection.
Then it started getting lumpy. Sounded awesome.
http://youtu.be/mpiNZmf2_W0
But then I got home and it sounded like this.
http://youtu.be/jMJBT5LI6hQ
Sounds coming from the cams. Any ideas? When you rev it the noise goes away. Broken valve spring or something?
On the plus side it went hard :)
Edited by B.L.Z.BUB
Check the pulleys stuff first because they're easy to see. Then i'd be pulling the valve covers off and have a poke around.
Maybe supercharger? these are clutch type right? But I know nothing about sc12's
Definitely sounds like a rotating noise.
Ok so I pretty sure exhaust and inlet cams are the same, just out 180 degrees, yeah?
But when I put the engine to TDC to measure the valve clearances the cam lobes arent at the lowest point.
When I turn them so I can read the gap like so...
The cam gears are nowhere near the timing marks.
Then I noticed this:
Soooo, c'mon guys, WTF is going on here?????
I'll be the first to admit I've got nothin'... Although the camshaft knock-pins being out of alignment can't be good unless the cam-spec's require it. Any part or ID number on the cams that you can see?
