bwendaman Posted November 26, 2011 Report Posted November 26, 2011 hey guys just wondering if anyone had any idea how to get this threaded Alan key bolt out? Alan key was bad quality and it slipped and now can't get it out? it's a small bolt that goes through my wheel into my boss kit, need re- allighn steering wheel but can't without getting this threaded bolt out. can anyone help me? would be much appreciated Quote
B.L.Z.BUB Posted November 26, 2011 Report Posted November 26, 2011 Use a small flat head screw driver and hammer it in the hole. Quote
altezzaclub Posted November 26, 2011 Report Posted November 26, 2011 I have both allen keys and also the small bits that fit into a hollow screwdriver or 8mm socket. Often the small bits are better quality, so they might be worth a try. Quote
Jono.C Posted November 27, 2011 Report Posted November 27, 2011 I had this same problem on mine, i hammered a slightly larger imperial allen key into the groove and it came out easy Quote
irokin Posted November 27, 2011 Report Posted November 27, 2011 On 11/26/2011 at 3:15 PM, bwendaman said: need re- allighn steering wheel but Why? If your steering wheel WAS centered and has now gone off center then the answer isn't adjusting the wheel to be correct. Something in your wheel alignment is out of adjustment and needs to be corrected. Quote
bwendaman Posted November 27, 2011 Author Report Posted November 27, 2011 thanks for the help ;) appreciate it guys Quote
