  • Replies 416
Yeah, if you could send me those diagrams that would be sweet Biggo.
Did you guys notice a big difference with the ABV deactivated? I'm guessing I'd get about 1.5-2psi extra boost, so I would hope for some rather noticeable extra power.
Yep, standard KE55 (1981 model) brakes. I've got some Bendix Ultimate pads for next time, but I will be upgrading to RX7 brakes as soon as I've saved enough cash.
Biggo - I'll email as soon as I finish writing this.
ive been thinking of the front mount for 4AGZEs, one thing to remember on a GZE is the throttlebody is placed before the supercharger, and the intercooler is after the supercharger. the problem with having a front mount is if you blow off a intercooler pipe, crash or get a rock thrown up that makes a hole in the cooler it will be the same as opening the throttle full and youll have no control over throttle.
A turbo setup or even my setup has the throttlebody after the blower so if something happens to the cooler i just loose boost.
Aslo keep in mind why topmounts on 4AGZEs are used. Less likely for this to happen and the intercooler moves with the motor so not much chance of blowing off IC pipes.
I think something like a water to air would be better option
Interesting point, and one I hadn't considered previously. No-one has yet swayed me to getting a front mount, in fact, the only argument for one is how much room I have in front of my radiator currently, but that won't change my mind. Water-to-air all the way (that or a better top mount).
EDIT: Later on I intend to do something to clean up the intake manifold. I may look into changing the standard setup rather dramatically (possibly so that the supercharger is before the throttle body/bodies). This will depend on cost though, but I like the idea of a quad throttle 4A-GZE.
Edited by ancullen
Yeah, for stock GZE's. I don't see why the SC can't just feed a plenum chamber which leads into the throttle bodies, like a turbo setup. The ECU will need to be reprogrammed to accept the changes, but as I've already got a Microtech on board it shouldn't be too much of an issue I would have thought.
Its been awhile eh..but glad to hear lola's back on the track! :wink:
That bonnet scoop looks neat as it is. should turn up nicely when the front end's done. :y:
I will hopefully be taking Lola to a dyno day this Sunday, but it's will depend on how much money I have to burn. I may be able to do the ABV mod in time, but I somehow doubt it, but at least this way I can get a baseline to know where future mods will take me power-wise.
Change of plans. Decided that the $60 would be better spent on actually racing or improving the performance of Lola. I can get a dyno test done when I'm actually getting her dyno tuned.
