I'm looking to get the most out of this little gem ( want to keep original engine for size class racing) , any tips, hints or help would be cool .........( just don't say drop a 3k,4k, 1uz ect ect , cause I'm not interested)
bore out to 60th, shave head until 12:1 compression, bigger cam, extractors, weber if your allowed, port and polish head, bigger valves and springs, fully balance motor, deck block and yeaaah
Before you balance it lighten the crank and knife-edge it, and I'm sure you have a lightweight flywheel for it.
If you're not driving it on the road you'll want it as light and free-revving as possible.
the engine is in my ke15 '68 , looking at track, hillclimb, motorkanna , and eventually targa tasmania ( this is the reason not to just chuck a bigger engine in)
Edited by drewsith
Targa is a dream of mine. Sounds like you already have the advice you need, but do you think a larger diameter exhaust system would be worth the money? Or just an overkill because of the small size of the engine? Maybe just sports muffler?
