Feral4K Posted November 7, 2012 Report Posted November 7, 2012 ANother manifold too keep a keen eye out for is the "SK Sanyo " veeery rare for a k series but also one of the best also TRD but we all know that Quote
altezzaclub Posted November 8, 2012 Report Posted November 8, 2012 Ah.. if only the motor stood upright! Quote
snot35 Posted November 8, 2012 Report Posted November 8, 2012 Sorry, but that is where my philosophy differs, paying 5 times what I paid for my last 4K plus gearbox? Pass :) On 11/7/2012 at 7:56 AM, JDMJared said: If any motor is worth it, it's the K motor! The manifolds go for about $350 on Yahoo auctions + postage to Streeter + Streeters commision + postage to Aus You might get one for $500 to your door. And you know it's going to be top shit, Kameari are the go to guys for L-series - they make a mean looking set of 6-1 extractors. Quote
JDMJared Posted November 8, 2012 Report Posted November 8, 2012 On 11/7/2012 at 11:51 PM, Feral4K said: ANother manifold too keep a keen eye out for is the "SK Sanyo " veeery rare for a k series but also one of the best also TRD but we all know that Yeah there's one of those on Yahoo atm, used, $200ish, looks like a decent manifold. Quote
kickn5k Posted November 8, 2012 Report Posted November 8, 2012 On 11/8/2012 at 5:55 AM, snot35 said: Sorry, but that is where my philosophy differs, paying 5 times what I paid for my last 4K plus gearbox? Pass :) Well then you'll fall over when you hear what my 5k will cost. Quote
snot35 Posted November 8, 2012 Report Posted November 8, 2012 No doubt. As I said, my philosophy probably differs! Quote
Feral4K Posted November 9, 2012 Report Posted November 9, 2012 ALlrighty so what do we all consider silly money to spend on a k series to make good power?? I Know kikn5k has spent some good money to get his goin, and a few others also. Real power costs money how fast you wanna go is up to your back pocket and talent you have to keep costs down( fabrication assembly etc) My ke10 is a toy for me and my boy to play with and ill be throwin some money at it to make sure its good before he gets in it, Luckily I'm a panelbeater spraypainter so that should make this venture quite affordable. Ps The fastest na k series challenge on another rollaclub forum has me excited i beleive kikn 5k is building one for the title we might join in with the feral4k...... Quote
Farch Posted January 21, 2013 Report Posted January 21, 2013 my engine machinist told me that 4k's will start cracking blocks if pushed past 8000rpm, they need to be aleast part crout filled to stand up to those harmonics. and all that assumes that your rockers arms are still attached to the engine. your rods should be ok i've heard that factory 4k rods are pretty stout and handle quite abit of punishment. when I get my ke55 back from the tuner I'll tell how it goes, it's pretty much much stock bottom end but with 3k head and 295 cams and 8000 redline and twin carbs. if i blow it up quick you'll know your answer lol. Quote
altezzaclub Posted January 21, 2013 Report Posted January 21, 2013 Quote it's pretty much much stock bottom end but with 3k head and 295 cams and 8000 redline and twin carbs. What sort of flywheel? Did you have it all balanced? Quote
Farch Posted January 22, 2013 Report Posted January 22, 2013 just took way too much off the stocky, has gone from about 7.5ish kg to some like 5.7kg and yes the whole rotating asbembly was balanced. Quote
altezzaclub Posted January 22, 2013 Report Posted January 22, 2013 That should be OK. Mine is about 6kg. There are a couple of guys on here reckon 8000rpm is possible once they're balanced, but the factory bakance is not good at all. Philfrederick's twincam 4K hits nine, its still a 4K crank but its been pretty heavily machined. Quote
filfrederick Posted January 22, 2013 Report Posted January 22, 2013 the main problem i found is the crank, it is cast iron and only semi-counterbalanced so as the revs increase each individual throw becomes more out of balance and that creates crank-whip and will crack in the big end radius. to try and reduce this i machined a lot of weight out of the counterbalances and polished and shot-peened it, never had a problem, but it was not sitting at 9500+ all day. luckily i didnt have to worry about all the pushrod stuff, that is a lot of stuff flapping about up there. mine stock after machining and before shot peening Quote
Farch Posted January 22, 2013 Report Posted January 22, 2013 looks sweet, I put spool forged rods in mine so it looks like I'll destroy the crank and block before anything else. I've limited mine to 8000rpm my cam is rated from 3500 to 7500 for that reason. but how power can I expect from these engines? this is my first 4k build. Quote
GJM85 Posted January 23, 2013 Report Posted January 23, 2013 You can boast if you get 70kw out of a NA 4k. Quote
