well its got over 100hp at 6200rpm but i feel like bigger cam bigger exhaust more boost and wondering how many frevs the poor little rods will jump out haha
you wont shoot rods out the block or blow cranks on a 4k, (a bad tune and detonation will!)
stock rpm is 6250.
my balanced camed 4k pulls 7 grand
a local wrecker who races speedway was telling me how he had to get special pistons from the states with 1 inch skirts on the pistons on his 3k, spins 11 grand.
ill believe it when ill see it mate
edit - crow 4220 double valve springs FTW
Edited by Evan G
OK ive posted about my old KE70'S Engine before but everyone calls BS everytime i do. It was a 4k block, bored 60thou (not sure if id be doing that on something running boost) Fully balanced rotating assembly, HUGE cam and quite a bit of compression, head, inlet, extractors were all ported to flow more and it spun to just over 10,000 RPM and absolutely flew. Made 74rwkw on the dyno but the operator wouldnt turn it past 7000 RPM lol.
This was built by a bloke who had 30+ years experiance building speedway motors and this one was originally in his sons KE70 speedway car. Built right they CAN rev hard but like anything once you start pushing the envelope itll shorten the motors life.
That motor lasted nearly 4 years and ended up just losing compression and never actuually died ( a mate still has it as far as i know). but i don't think with boost itd be the same story lol.
A stocker will see just shy of 8000 before valve float.
It will rev happily at 7000 all day long. However it may not take many days of that kind of treatment.
I got a total of 24 months of abuse out of a 4k with regular trips to valve float, but wasn't using it it every day.
Ultimately, some engines last longer then others, but if you keep a stocker under say, 7200 you should have no troubles. :wink:
  • Upvote 1
