ae71wagoneer Posted October 4, 2011 Report Posted October 4, 2011 my ae71/4ac suddenly over-heated the other day,i'm not sure why.it ran fine at normal temp till i dropped a mate off,got about 1k up the road and the temp was off the clock!please help.:bash: Quote
Evan G Posted October 4, 2011 Report Posted October 4, 2011 milk shake under the cap? steam out the bonnet? was it getting hot or was the gauge just showing high? how hot was the radiator hoses? somethings you should check before the next step. check the operation of the thermostat, water pump and radiator. removing the thermostat only covers the problem not solves it. 1 Quote
Jackson Posted October 4, 2011 Report Posted October 4, 2011 Check ya radiator hoses, if the bottom is hot and top is cold ya thermostat is stuck shut. If its not your thermostat check ya flow across the top of your radiator, should be like a river if your water pump is good (let your car warm up with the cap off to check this) How old is your radiator? Mine recently started overheating at cruise speed (80-90k's) turns out the radiator was blocked up with shit loads of scale. If your coolant is really frothy or it is dumping heaps in the overflow tank chances are your head gasket is frucked. Quote
Spencer[RL] Posted October 4, 2011 Report Posted October 4, 2011 Pretty sure I've read in some manual that when a 4ac over heats it means it's crying for a 4age? I could be wrong? Quote
Evan G Posted October 4, 2011 Report Posted October 4, 2011 Pretty sure I've read in some manual that when a 4ac over heats it means it's crying for a 4kc? I could be wrong? FIXED* Quote
ae71wagoneer Posted October 5, 2011 Author Report Posted October 5, 2011 radiator was blocked.quick blast with the fire hose,problem solved!thanks for the help :yes: Quote
ae71wagoneer Posted October 10, 2011 Author Report Posted October 10, 2011 problem has returned!notice oil and water coming from the back of the motor :bash: Quote
jinsoku Posted October 28, 2011 Report Posted October 28, 2011 looks like it's time for a 4ag!!!! Quote
ae71wagoneer Posted October 28, 2011 Author Report Posted October 28, 2011 it was just a split heater hose!!!!!!!!!!!!!!:dance: Quote
