dbr11k Posted March 8, 2014 Author Report Posted March 8, 2014 updated work list, didn't realise how much I've actually done to this thing... front: Ae86 ajps coil over sleeve kit Ebach 8kg springs Koni shocks Willwood 4 pot callipers Willwood 288mm slotted & Cross drilled discs Willwood Full race pads Steel braid teflon brake lines T3 extended adjustable tie rod ends T3 roll centre adjusters T3 shortened knuckles Ajps lock spacer superpro rack bushes new rack ends T3 rose jointed adjustable lower control arms T3 rose jointed caster arms Cusco camber tops Cusco strut brace cusco lowered engine mounts cusco gbox mount Rear: F series diff with Lexus TRD 2way LSD Modified diff mounts with welded traction brackets Custom 6061 alloy CNC Machined caliper brackets twin r33 skyline calipers speedflow -3 braided brake lines T3 rose jointed adjustable 4link trailing arms T3 rose jointed adjustable panhard Whiteline 19mm blade adjustable sway bar 6kg ajps springs ajps height adjustable spring perches Trd blue 8way adjustable short stroke shocks body: sheet metal floor front inner guards replaced with 48mm tube front custom tube lower radiator support 4 bonnet pins welded in engine bay custom quad headlight brackets shaved front indicators shaved antenna shaved front door handles with pop button on sill Flat front with DX quad lights shaved fuel flap front in rear flares rolled and pumped flares rear doors welded shut rear door hinges welded rear door handles shaved sheet metal 'ute tub' sheet metal rear firewall deleted A pillar gutters smoothed custom shaped B pillars 48mm CDS tube bracing between B & C pillars bracing between spring perches and C pillars bracing between rear chassis rails Isuzu dmax rear tailgate welded solid probond composite sheet hard tonneau 4 point roll cage seam welded bay and chassis interior: sound deadener stripped interior battery mounted passenger footwell 2 bucketseats takata harness alloy dash board speco gauges battery isolation switch shortened steering column cheap drift wheel quick release boss Willwood hydro handbrake master cylinder Willwood brake bias adjuster custom hydraulic handbrake lever 40lt fuel cell dropped 1.5 litre surge tank Bosch 044 carter silver series lift pump mounted under car running through interior > speedflow -8 fuel feed speedflow -6 fuel return speedflow -4 hydraulic handbrake speedflow -4 rear brake line bulkhead fittings throughout driveline: Airies pistons ZE rods Arp rod bolts Arp main studs Arp head studs Cometic head gasket Reconditioned cylinder head Custom GCG built GT28 66 spl roller bearing turbo 38 mm tial waste gate, Screamer pipe 3 inch dump pipe custom steam pipe manifold 700cc sard injectors Blacktop individual throttle bodies Custom Hypertune plenum Custom Hypertune intercooler Custom Hypertune intercooler pipes Custom Hypertune alloy radiator/oil cooler combo 2 x 10 inch thermo fans, custom sealed shroud Custom Hypertune header tank/ water distribution setup Custom Hypertune Rad overflow/Oil catch tank Grex sandwich block to suit oil cooler Grex Thermo oil re route block Steel braid hose & Speed Flow Fittings throughout Extreme 5 puck ceramic clutch Extreme 3.9kg flywheel knight parts bell housing reconditioned Steel plate W58 supra twin turbo gear box Custom ae71 Gearbox x member Custom one piece 3 inch tail shaft hardy spicer joints Haltech E8 computer LS1 coils mounted under dash Tuned By JEM shoes and socks: 2 sets of 16x8 rota grid (rays te72 copy's) -4? offset nitto nt555 205/45zr tires Quote
dbr11k Posted March 8, 2014 Author Report Posted March 8, 2014 Skyline lights. I did see a few pair of 32 lights for sale, an a cheap pair of r34 lights too.. tempting Quote
B.L.Z.BUB Posted March 8, 2014 Report Posted March 8, 2014 Just wondering if they would be too curved. R31 lights maybe. Quote
dbr11k Posted March 10, 2014 Author Report Posted March 10, 2014 marked out the holes for my gauges tonight.. have oil press, water temp and volts.. need to save pennies for the other 5 gauges air fuel ratio, boost/vac, oil temp, fuel level, fuel press spent most my day cleaning this poor old girl up, need to get on an rebuild the motor soon Quote
dbr11k Posted March 25, 2014 Author Report Posted March 25, 2014 so got all my gauges wired up, fitted fuel sender to my cell, got a lot of body work done on her, heat wrapped the exhaust with titanium wrap. made a gear knob cause I'm broke. finally put 100 micron Holley filter before the pumps. got the foot brakes plumbed up and discovered the system is gunna need a bigger master cylinder, using bm44 with s13 boost 15/16 should be plenty big, if not I'll try 1" pbr master. other than that not too much happening, trying to move to the Gold Coast so saving all the money I can.. need to sort out paint, tonneau cover and windscreen/rear window as well as hydro master cylinder, which all require $$ happy snaps, and trying to light her up in dad's tiny ass shed with too much traction and shit brakes lol Quote
dbr11k Posted March 31, 2014 Author Report Posted March 31, 2014 bm44 15/16 master and original booster installed, was a pretty tight squeeze but fits like a glove and the brakes feel amazing now ???? Quote
dbr11k Posted April 8, 2014 Author Report Posted April 8, 2014 progress.. won't be welding a cage in, just wanna drive an no money for pipe.. so bracing the car and gusseting along with welding harness points if needed. fuel tank sender done and cell vacuumed out. interior panels welded in, onto the rear doors next. re angled my exhaust to tuck up neater. stripping the interior down again once finished to paint with por15 me an Bella have been creating a rocket with 2kg rcandy motors Quote
dbr11k Posted April 10, 2014 Author Report Posted April 10, 2014 does anyone even get on these forums anymore or what lol seems to me every pricks migrated to Facebook.. even quiet on other forums like ae86dc and hardtuned Quote
B.L.Z.BUB Posted April 10, 2014 Report Posted April 10, 2014 Yeah all forums are generally quiet now. Good for tech builds and stuff but not so good for sales. Facebook pages are getting pretty bad. Quote
67Rolla-Ken Posted April 10, 2014 Report Posted April 10, 2014 I'm always reading all the threads, just don't post much. I'd guess there are a lot of people in this boat. Quote
JimL Posted April 10, 2014 Report Posted April 10, 2014 (edited) Yep same with me, lurk a lot and thoroughly enjoy reading all the build threads, but I don’t bother posting because I don’t have a heap of technical knowledge to contribute. The Ute is looking mad btw, very unique. Edited April 10, 2014 by JimL Quote
B-Lugg Posted April 10, 2014 Report Posted April 10, 2014 Don't know how I've managed to miss this thread - I always thought that this thing was a just hacked up for fun going by the pictures on Facebook. Seems like your switched on and it will be one hell of a car when it's done! Good job! It really is a shame that Facebook is now my only source for parts now with the exception of retailers, that website is crammed with crap. Quote
