Hey guys
my temp gauge on my ke70 has stopped working,i got a new sensor but still no go,i then tried earthing the temp gauge wire and the gauge went to hot,so i got another new sensor but same issue again??? can't have got 2 dodgy sensors... could it be something else i should look at???
Cheers
I got new sensors from supercheap,but a funny thing happened the other day,took the car up to 140kph and the gauge started to work...WTF??????
Just keep the car above 140kph then, simple.
  • Upvote 1
lol! that's what it takes to warm it up!
Maybe the thermostat is jammed open, so it doesn't warm up- check the rad gets hot, 75deg is too hot to keep your hand on..
or as Medicine Man says, the sensor has the wrong resistance. I bought a correct Pintara one from the catalogue a few weeks back, it didn't even fit the threaded hole. A Nissan 4WD one fitted but refused to warm up on the gauge, and the third one (a 240SX I think it was) works fine.
Have another try at Supercheap for a different resistance value. Mine is 1175ohms on the 2000ohm scale of my $10 yellow multimeter, and that's at about 15deg in the garage right now.
