LittleRedSpirit Posted September 23, 2011 Report Posted September 23, 2011 Look for any vacuum lines that are damaged, split, or perished. Look to make sure that all openings on the manifold are closed. Make sure the TB is in good order and that it shuts all the way. Look over the alloy cast manifold, castings are known for cracking. Especially around the bolts where it mounts to the head/tvis plate. Make sure the manifold is installed with the right gasket too. Inspect the tvis plate too. It might crack or leak somehow. Quote
ke70-dori Posted September 24, 2011 Author Report Posted September 24, 2011 YEWWWWW! after almost giving up i found and old thread that covering up a hole in the throttle body works... and it did! cheers for all the help everyone much appreciated :) Quote
