I wouldn't pay $250 for something that is meant to stop me dieing if the good shit is thousands. May as well put a plastic one in and throw some illest stickers on it.
$250 second hand....
You'd mostly use it rigidity anyway. And IF you were serious about safety with a cage you'd go full cage anyway! As half cage won't do shit if you flip onto a fence
Edited by Jono.C
It shouldn't as far as I know pass the old regs either. I know in Motorsport circles 45mm main hoops have been the go for years.
Guys, please don't think I'm picking on you. I trying to talk to you as someone who has both tested a cage, and seen many others tested as well.
If you look at the majority of cusco cages and the way the rear stays are connected, I personally believe They offer very little in the way of rigidity. Spend your money on something worthwhile.
Guys, guys, hey....
Guys.
Um, can I use my stock KE70 brake lines with corona sumitomo twin pots? Please say yes. The holes seem very different. Same gauge and thread , but different.
Edited by B.L.Z.BUB
Yeah. I was thinking of getting them swapped out but my hoses are actually in worse condition than I thought. Everything else in the front end is new.
Plus the old ones aren't long enough.
Edited by B.L.Z.BUB
If it's anything like GTR calipers you can remove the olive with easy outs and use it like a regular banjo bolt mount. The banjo sealing surface is even cast into the caliper. I've seen others trim down the banjo bolt which is a bit sketchy but it works.
