Hi guys my 3k's buggered , I am putting a good condition 4k in my ke35 , but is was wanting to know if there will be any problems with the 4k in there for the road worthy and vic roads . Because the 30's never had 4k in them . Has anyone done this with out any hassles ?? Thanks
changed to a 5k in one of my old KE35. VicRoads couldnt care less. All they wanted was the engine number. Most people wouldnt know the difference anyway.
Ok! I suppose I just have to do it and find out . I guess If you got some one that knew then they might pick up on it? But it's hardly a massive upgrade
Haha I wish!!! I had to get my 5k engineered in my KE-11.
Which technically is correct, your allowed 10% increase without an engineers. Seeing as it's only 100cc bigger you won't have a problem.
Stu.
Stu.
the engineer i spoke to said 30% bigger in power
so i can't legally put a 5k in my 55 hence me gonan sell it...
I was just speaking with an engineer he says it might pass but it really should have an engineers cert for it . I am not sure what to do should I just wack it in and try my luck or not??
Edited by Gtr rolla
That has to be BS! What would an engineer looking at it do for road safety?? He can't look inside, he won't know how much power it makes, and as it sits on factory fittings it should be perfectly safe.
Take a number punch and change any "4K" in the engine number to "3K" and slap it in!! :laff:
Yeah I think it's a load of BS too , he says beacause the 4k was not an option for a ke35 . He said just flap it in and try your luck! But I don't want put it in and be stuffed about over a pissy 4k engine. I only need it to get the redgo then it comes out for a bigger engine set up' witch I won't be worrying about engineers certs , I'll just keep the same numbers . Who cares 
