terryo Posted September 8, 2011 Report Posted September 8, 2011 does anyone know if all the KE rear brake plates have the same bolt pattern where they bolt onto the diff. I have a 200mm drum set up on the KE17. the bolt pattern on the backing plate is 70 x 70 x 70 x 70. is that common to all the KE's with small brakes??? does anyone have a Tercel one??. they are 200mm but wider brake shoe Quote
camerondownunder88 Posted September 8, 2011 Report Posted September 8, 2011 (edited) :bash: I read front...you typed rear...so my info is useless but still handy. Hi Terry, can't tell you exact bolt spacing but the KE15 I run I removed the front discs and fitted KE70 discs with KE70 calipers on KE30 backing plates. All early corollas have the same square bolt pattern KE1X,2X,3X. 55 and up they changed. Only difference KE30 uses bigger bolts to hold plate on. Also when fitting brakes KE1X struts need drilling and re-tapping for the larger bolts. Cheers Cameron Edited September 8, 2011 by camerondownunder88 Quote
parrot Posted September 8, 2011 Report Posted September 8, 2011 Out of interest I just checked a TA22 diff I pulled out of a car on the weekend. That is 50 x 80 x 50 x 80 Quote
terryo Posted September 8, 2011 Author Report Posted September 8, 2011 thanks, the 50 x 80 is common I recall. i have a RA40 diff i'm shortening and thats the size on it. Quote
