drift freak Posted August 4, 2014 Author Report Posted August 4, 2014 So tax time has been good me this year, along with the new front end set-up for the 11 I picked up from a mate I also managed to grab a bargain and buy a Datsun 1200 Sedan with 5 months rego. The car is totally stock with the original A12 and 3 speed auto. I needed a cruiser and this fits the bill perfectly. I will be giving her a coat of original white, some wheels, patch the interior up (no carpet and seats need re-trimming) and a manual conversion to make her a little more enjoyable to drive. Don't worry guys and girls I still have plans to have the 11 back on its wheels and ready to be tuned in the coming months. It just means the paint and interior will have to wait until next year haha Quote
Jono.C Posted August 4, 2014 Report Posted August 4, 2014 Now you have 2 white datsuns, Just one has a beams ;) Quote
drift freak Posted August 14, 2014 Author Report Posted August 14, 2014 So a few things have been going on lately with the new front suspensions setup and body work. Firstly I have mounted up the front suspension and had new camber plates made to suit the K-Mac tops I now have. This setup gives me around -3deg camber and more than enough castor. I also finally finished the shifter surround in the gearbox tunnel. It should look much neater once its got some sealer and carpet over it Now to just grind back a few welds and get the underside sealed up :) hopefully it will be back on her wheels and driving by next weekend Quote
drift freak Posted August 14, 2014 Author Report Posted August 14, 2014 Cheers 67Rolla-Ken, I can finally see the end of the tunnel in regards to the bodywork and the whole project for that matter. I am just stoked to have the welding done and it nearly ready to be removed from the rotisserie. It will be nice to have some space back in the shed to have a clean up :) Quote
Birksyy Posted August 15, 2014 Report Posted August 15, 2014 I'm really not keen to start seam welding! I've read this thread so many times now, I love it!! Quote
drift freak Posted August 15, 2014 Author Report Posted August 15, 2014 Just a word of advice Birksyy, make sure your seams are extremely clean before welding. On a couple of mine the sealer had melted between the panels and caused the welds to be less than desirable due to contamination this caused me to go back over a couple. Also it might be easier to drill extra spot weld holes on all the accessible areas and weld it up like that, I read an article about seam welding the other day and they were talking about the stresses on the steel from welding the edges like I have. Probably not a bad idea to stitch it instead of laying seams to, would make it much neater. Quote
autofill Posted August 17, 2014 Report Posted August 17, 2014 just letting you know that i make dry sump pans to suit the altezza and 3sgte motors to rwd .total pan depth at the pick ups is 85mm Quote
drift freak Posted August 18, 2014 Author Report Posted August 18, 2014 Got any photos autofill??? Not sure where your taking your measurement and if it will much help for me. Quote
autofill Posted August 18, 2014 Report Posted August 18, 2014 hows this then ps i sold you the quad throttle adapter will bolt up to the block and the cas will also have enough room to work 45mm deep at the back and std altezza windage can bolt in as well Quote
drift freak Posted August 18, 2014 Author Report Posted August 18, 2014 Cheers Glenn, how much $$$ are you looking for???? Not really needing one for now but might invest later on. Quote
autofill Posted August 19, 2014 Report Posted August 19, 2014 there 650 each plus postage drilled and machined to suit altezza 3sge including the dowell holes as well Quote
drift freak Posted February 15, 2015 Author Report Posted February 15, 2015 So its been way too long between updates on the old girl as I've been busy with other things. I have however been doing little bits and pieces over the last few weeks and this weekend presented a major milestone completed. I FINALLY sealed the underside of the old girl which will allow me to get her off the rotisserie and move ahead with the painting inside and reinstalling the driveline over the next few weeks. A few pics to show everyone what happened. Quote
67Rolla-Ken Posted February 15, 2015 Report Posted February 15, 2015 What are you painting her underside with? Looks a bit like that bed liner stuff. Quote
drift freak Posted February 16, 2015 Author Report Posted February 16, 2015 Hey 67Rolla-Ken, It is a spray on under body sealer. I bought is from my local autobarn store. It is 'Motorspray - stone guard'. You use a special gun that screws to the lid of the can and sprays out through a 7mm nozzle, it gives a textured finish that protects against rust, stone chips and helps with road noise reduction. They use it on most new cars too. Quote
