01sik Posted September 2, 2011 Report Posted September 2, 2011 which model falcon? can't find anything or maybe I'm just stupid :( and does anyone know what kg rating they are? or are they just HARD? cheers james Quote
rian Posted September 2, 2011 Report Posted September 2, 2011 (edited) XD up to AU apparently. From what I can remember of my friends car; they were pretty stiff and super bouncy with standard shocks. I can imagine it would get fairly annoying after a while too. Maybe get some aftermarket springs to suit a KE70? That way you can choose your spring rate and length, they are fairly cheap too. Edit: this is for the rear of your KE70 right? Because I'm not sure what fits in the front. Edited September 2, 2011 by rianwest Quote
Evan G Posted September 2, 2011 Report Posted September 2, 2011 for ke30/55. use EB rear king springs (chop chop) for ksev use au rears kings choppies Quote
bAKER Posted September 2, 2011 Report Posted September 2, 2011 pretty sure the ones in the front of my kesev are from an el falcooon. Quote
B.L.Z.BUB Posted September 2, 2011 Report Posted September 2, 2011 (edited) http://www.google.co...lient=firefox-a how hard did you look for info? I'm afraid yes, you may be stupid :wink: http://www.googleguide.com/ Edited September 2, 2011 by blzbub666 Quote
Evan G Posted September 2, 2011 Report Posted September 2, 2011 On 9/2/2011 at 9:32 AM, bAKER said: pretty sure the ones in the front of my kesev are from an el falcooon. I'm almost 90% sure Brent is running au's? Quote
Millaz88 Posted September 2, 2011 Report Posted September 2, 2011 How do you run coons spring in the front I tried they just kept popping out cos they were like 5mm bigger diameter then stock Quote
Evan G Posted September 2, 2011 Report Posted September 2, 2011 thats not good! what model coon were they out of? Quote
Millaz88 Posted September 2, 2011 Report Posted September 2, 2011 They were el springs I just took them put but vl ones work good There diameter is smaller then fords Quote
Evan G Posted September 2, 2011 Report Posted September 2, 2011 sounds like you got ae86 struts? Quote
Millaz88 Posted September 2, 2011 Report Posted September 2, 2011 If I do I don't know about it lol Quote
Evan G Posted September 2, 2011 Report Posted September 2, 2011 ive heard vl springs running in ae86's. find some info and check it out. you might half way thru a strut/brake upgrade Quote
Millaz88 Posted September 2, 2011 Report Posted September 2, 2011 Anyone know the shock tube measurements? I'll give it a measure up Quote
01sik Posted September 2, 2011 Author Report Posted September 2, 2011 On 9/2/2011 at 9:36 AM, blzbub666 said: http://www.google.co...lient=firefox-a how hard did you look for info? I'm afraid yes, you may be stupid :wink: http://www.googleguide.com/ hey man don't hate on the new guy lol.......i did look but silly me i searched on this site and not on google, thanks for the links but mate i had a read :) cheers for the replies lads ill have a look at the wreckers today for some. Quote
lildavo Posted September 3, 2011 Report Posted September 3, 2011 The springs rates will probably vary a bit through the different models, you'll find the xr and tickford falcon will be a higher spring rate. Does anyone know the specifics on this? I googled a bit but couldn't find anything... What's a good free height to chop them down to? Also what shocks match up well with them? Quote
