I had a thought last night with the airbox. It might be worth installing a place where you can hook up a vacuum pipe. Then you could hook it up to your ecu via a second map sensor and log the inlet manifold pressure to see if you are getting any pressure drop/restriction over the air filter. You could even install your air temp sensor in it too. The air temp sensor from a GM car would fit real nice (~vs commondore have a nice flush sensor, I've go one here somewhere)
nice updates!
the black door cards are quite nice on the spoontahs. power windows or manual?
I'll send through an update on the ol Airbox today or tomorrow ;)
Got a heater core coming too! Winter sucks!
Try living south of the border!!
Been hovering around the 13-14deg for the last week in Vic.
Air box sounds interesting.
Try going further south, Been like 10 degrees here.. Went out to lock my car last night and my gentlemans area went inside.
It was 5.6 degrees outside lastnight when i went to put my washing out. and was still around the same temp this morning when i went to work..
I miss my working heater box in my yellow ke70 :(
and dave Ive been thinking, there may be a better shaped filter and airbox to modify in that gives more filter area and ease of connection to the box. I might have a wreckers dig before I go much farther with this, and see whats out there with a bigger inlet hose and filter. I'm wondering if the filter we have off a small pulsar will be enough area?
It woud be nice to have the air filter go all the way along the bottom of our box.
One option might be subaru non turbo airbox. They have a long skinny air box that sits where the intercooler is on the turbo models. (possibly liberty?)
Ignore the green circle..note the airbox.
http://i146.photobuc...zpsa63b8477.jpg
and here is the filter size
http://www.rycofilte...ies//part/A1426
which is 371mm long apparently, our box was only 400 long wasnt it? pretty close.
edit:
http://www.ebay.com.au/itm/Subaru-Liberty-Gen-3-Air-Box-Assembly-98-03-Perfect-Condition-/321450105218?pt=AU_Car_Parts_Accessories&fits=Make%3ASubaru&hash=item4ad7eb5982
thats the one i mean i think.
Edited by ke70dave
It would interfere with the clutch master if it was too far back on the base of the box I reckon. But that looks good. Id love to know how big the inlet hose is too..
Edited by LittleRedSpirit
