Ripped the motor out and took all the bits over to NPC.
I had a chat with Doug about the different things we could do.
I explained what I had done and what I was trying to do. He suggested it might be easier and safer than modifying a flywheel to make a billet one from scratch. We are going to try and use a 10 inch skyline clutch, and failing that, a 9.5 inch Toyota one.
The y flywheel is a smaller diameter over all, but they both actually seem to have the same size clutch disc.
9.5" would be plenty. Flywheel shouldn't cost too much although a one off, maybe get a couple if you can offload them, or do you want to be the only one with a RWD 2az haha.
They will have a cnc program for it, so anyone will be able to easily get one if they contact NPC. It is the only drive line part you need that is custom.
Beyond that its just mounts, manifolds, tensioner and the oil pickup that really need mods or fabrication. Not easy, maybe a little harder than a 3sge conversion as you need a flywheel that doesn't exist and nobody has run them north south very much at all.
I have one other photo from a Japanese American professional drifter who was building a 2azfe ae86 pure race car. It appears his motor slants left too, but not quite as much as mine.
can't wait now!
Yeah the put in the end of last year. Before that he had a 4AGE atlantic turbo.
Thats the 2az on the dyno.
Yeah I'm pretty sure its dry sumped, I read a really good article on it I'll see if I can find it
Edited by It's_AUDM_Yo
Yeah I just found basic info on facebook about it.
its over 500 hp and over 500 torque, I'm not sure what unit but Id assume NM. However these are yanks so maybe thats ft/lbs. If it is that just unbelievable.
Edited by LittleRedSpirit
