LittleRedSpirit Posted December 24, 2020 Author Report Posted December 24, 2020 (edited) Man its great up here, been making a few friends, I love it. The bank just approved our finance to build starting next month. Weve bought 1.2 hectares, 12,000 sq Metres, thats about 32 Brisbane house blocks, and were just dropping a big 3.5 bed home right in the middle of it, with a 12 x 18 x 4.8 high shed to follow soon after. Edited December 25, 2020 by LittleRedSpirit Quote
LittleRedSpirit Posted July 3, 2021 Author Report Posted July 3, 2021 Quick update. House is half built. Roof is on. Cars been sweet as can be. No real issues to report, just wear and tear from all the roadwork between here and Brisbane. Copped some gravel and rocks from trucks coming in and out of the quarry north of Gympie. Was lucky to not experience much more serious damage. Front bar took the brunt, and ejected the paint. Gave it a wash today. Much overdue. Quote
ke70dave Posted July 6, 2021 Report Posted July 6, 2021 It must be good driving the car so much. Good way to gain uber confidnce in the setup. And building a house too, all of the adulting. 1 Quote
Nickelbawker Posted October 29, 2021 Report Posted October 29, 2021 Buying a sawzall tomorrow, in preparation to pull one of these for my recently acquired 74' Celica. Looks like there are plenty of these but all of the 2AR-FE's are quite a bit further away so I'm going to get a AZ and then a 2AR later. Read a lot of the thread and will read more as well, very impressive a work of art! 1 Quote
Madmat1987 Posted February 3, 2022 Report Posted February 3, 2022 Wow what a thread. littleredspirit. Could you update the first post with the how to’s?? Id whats needed to do this swap please? Ie box, bell-housing, starter, etc id assume headers and i take are custom as well as all mounts. Id love to do this in a KE70 wagon Quote
LittleRedSpirit Posted February 6, 2022 Author Report Posted February 6, 2022 Yeah make mounts to suit your chassis. Custom headers and inlet. Y starter ring gear and bellhousing. Have a bellhousing set for sale if you're keen message me. Use a W transmission. I have a w57 now but will put a w58 in soon. Fuel system, wiring, ecu, tuning etc. Quote
LittleRedSpirit Posted October 10, 2022 Author Report Posted October 10, 2022 Time for an update because I have some work planned. Have collected everything I need to put Air conditioning in. I purchased or saved over the years; -a new oem Denso condenser - a new Spal fan for the condenser - working 2az AC pump from my 78000 k donor car and the pump ends of the AC lines. - all the OEM AC parts from the car including all the standard soft and hard lines, mounts, wiring to connect it up under the dash. - Spare AE86 heater switch block as mines a bit broken in the car. - New AC faceplate decal - New OEM heater core from Japan. I decided that its not worth just doing AC, I will fit a heater too. Things I need to re engineer to make it work; 1. Relocate oil cooler and lines. Make new brackets for it and possibly ducting. 2. Mount the AC pump and design the new belt and tensioner system to spin it. 3. Decide what kind of heater tap to use, where to mount it, and the hose path for it. I'm considering either an electric heater tap with a hidden micro switch in the AC switches to operate it, or a relocated cable setup. I think electric tap will be simpler with what I have going on in the bay already. Have treated her to a few missing parts as I've been able. I put in a rear hatch trim board which I bought new. I finally found a rear demister switch and bought it new also. Have replaced the headlight knob that had no writing left on it with new. I bought a top windscreen trim (again) as I will have to do a screen at some point maybe to re register as its got a big stone chip the size of a 10 cent piece on the passenger side. The old top trim has never fitted right as the windscreen guy didn't mount all the clips as needed so it just flies off at 100kph. Has happened twice now once on the Bruce Highway and was never seen again. I also bought a new rubber grommet for the bonnet post so it doesn't rattle, and a fuel tank pickup gasket to change next time the tank comes out. I have some folded and cut to size metal to make a new lower passenger seat rail to match the drivers and allow me to get rid of the modified ke70 rails it has. I also have the bride type seat slider to adapt to it. Basically building a copy of the drivers rail I have but reversed. Front wiper motor is pretty sad so will be swapping that to a better one. Also going to fit the rear wiper washer demister setup for the hatch as it rains a lot at the moment and Id rather have it in the car and I have all the switches finally. Car isn't currently registered but will be re registered after all that's done. Also lowered it and bought a better Jack so I can get under it at the lower height. Quote
ke70dave Posted October 11, 2022 Report Posted October 11, 2022 Ooooh nice update. You wont know your self with Air conditioning, it revolutionised the use of my e30, I can now go places and not turn up sweaty. and living up north it would almost be mandatory. Im sure you have it all sorted but if you need misc AC parts this guy was super helpful. https://speedyairspares.com.au/ He's up your way too. He went over and above looking for E30 bits for me. Quote
E30 drift Posted October 23, 2022 Report Posted October 23, 2022 On 8/28/2011 at 1:12 AM, LittleRedSpirit said: I'm using whatever throttles I can find with a 45mm outlet. I believe BT to be suitable but need to confirm the measurements. Expand What exactly is the bellhousing off I don’t under The y and s bellhousings haha Quote
LittleRedSpirit Posted December 29, 2024 Author Report Posted December 29, 2024 Hello Fam. I did get the AC to work, but its lost its gas in the lead up to christmas so I need to fix it again. Have just been enjoying it a lot lately. Maybe too much. Been giving it hell around the cane fields lately. Lots of fun. Have just clocked over 380000 klm on the odometer meaning its done about 57000 klm since the 2azfe conversion. I have lower klm odometers and about 6 sets of clocks for it but I like having the original one in there so I know the klm on the chassis. Have been fiddling with the tuning, have a pretty great startup now, and the plugs read brilliantly. Havent been on a dyno since 2020. I have enough parts to build a tuff motor now. Kelford cams, 286/278 duration and added lift. My CP 11 to 1 pistons, some molnar forged rods and some supertech valve springs, I have a couple full gasket kits as well. Should be a mad machine when I get around to that. Just thought Id throw in an update for the rollaclub family! peace. Quote
Big G Posted December 29, 2024 Report Posted December 29, 2024 She is still soooo pretty....looking forward to the engine build 1 Quote
ke70dave Posted January 8 Report Posted January 8 Good to see you've still got it. I hope life is treating you well up north:) 1 Quote
