hey i have a 1977 ke30 with a stock 3k motor and the thing is gutless can i get more power out of it or is it cheaper to drop a new engine into it?
Spend 150 on a 4k, drop it in. If your not happy with the power, save for a 5k, 7k or complete conversion
There is no point working a 3k if you can have a 4k for the price of a set of extractors
I'm in the same position, live in Canberra with a ke30 and am looking to do a swap, just thought I'd share lol what a coincidence.
Google is simply wonderful! 3k +/- 60HP. 4k +/- 60-65HP. Suprisingly a 4k wont give you much if anything over a 3k. This is all copied from wikipedia, and here is the link.
http://en.wikipedia.org/wiki/Toyota_K_engine
3KThe 8-valve OHV 1.2 L (1,166 cc) 3K was produced from 1969 through 1977. Cylinder bore was 75 mm (2.95 in) and stroke was 66 mm (2.6 in). 3K 60hp at 6000rpm. 3K-BR 84hp at 6600rpm. 3K-B 97hp at 6600rpm (compression ratio of 10 and 9).
The 1969 through 1975 3K-B was a twin-carb version. The California-spec 3K-C (1977-1979) and 3K-H were other available versions.
Applications:
Toyota Corolla
Toyota Starlet
Daihatsu Charmant
Toyota Kijang/First Generation Toyota Tamaraw
[edit] 4KThe 1.3 L (1,290 cc) 4K was produced from 1978 through 1989. Cylinder bore was 75 mm (2.95 in) and stroke was 73 mm (2.87 in). It was a 8-valve OHV engine.
In 1980, the 4K produced 60 hp (45 kW) at 5250 RPM. From 1982 through 1984, output was 65 hp (48 kW) at 5600 RPM and 72 ft·lbf (97 N·m) at 3600 RPM.
The 1981 and 1982 California-spec 4K-C produced 58 hp (43 kW) at 5200 RPM and 67 ft.lbf (90 Nm) at 3600 RPM. Torque was up to 74 ft·lbf (100 N·m) at 3400 RPM for the fuel injected 1982 through 1984 4K-E. The Japan-spec 4K-U produced 74 hp (55 kW) at 5600 RPM and 78 ft·lbf (105 N·m) at 3600 RPM in 1982.
