Your wanting to lock the dizzy? If so just tie the mechanical advance setup together with some mig wire or similar.
All I used for my supercharged 5k.
Stu.
Edited by kickn5k
Where do you live I could weld it if your local to me
But other then that just go into most mechanics they would have a welder and tell them what you want and they should be able to sort it out
Miller
Is the mechanism alloy or steel?? I'm looking into locking my dizzy as well, I'll weld it myself but if it's alloy I won't touch it.
Wont touch it cause you need a AC tig which is the price of a small African country! but have heard you can tig Aluminum on dc with heluim.
Just glue the sucker! A slop of araldite on the sliding pins would fix them in place.
If you're keen, replace the springs with heavier ones so it advances slower and at higher revs. Set it for mid-range and let it go up 10deg at the top end, at least you give it some extra time to burn.
I have to make sure that whatever gets stuck stays stuck. I'm converting mine to an EFI dizzy, so it needs to have 0 advance and the reluctor pickup has to sit a minimum of 60 degrees in advance
to the actual ignition moment. I think I might go down the araldite path, used it plenty of times.
Mine stayed stuck for 2 1/2 years. I checked it when I took it all out and was still perfect. You should be right with a good metal adhesive though.
Stu.
