Rollerin Posted August 15, 2011 Report Posted August 15, 2011 Sooooooooo is it possible to put SU's on a webber manifold for a k motor?? They look very similar, as in the mount shapes. Quote
Taz_Rx Posted August 15, 2011 Report Posted August 15, 2011 Maybe if you used 4 su's, but they wouldn't fit side by side. Su manifolds aren't that rare or expensive, just find one! ;) Quote
Rollerin Posted August 15, 2011 Author Report Posted August 15, 2011 I can't find su manifolds for a 3k any where, give me link if you do. Quote
B.L.Z.BUB Posted August 15, 2011 Report Posted August 15, 2011 http://www.carburetion.com/LynxManifolds.asp Quote
B.L.Z.BUB Posted August 15, 2011 Report Posted August 15, 2011 No idea. Get hold of them I'm not doing all your leg work. :wink: Quote
Rollerin Posted August 15, 2011 Author Report Posted August 15, 2011 Damn, thanks for your help :wink: Quote
altezzaclub Posted August 15, 2011 Report Posted August 15, 2011 The bolt holes are 76.5mm apart, and the carb must be angled to make the fuel bowl vertical. Quote
altezzaclub Posted August 15, 2011 Report Posted August 15, 2011 TOYOTAM120 MANIFOLD COROLLA 2 X DCOE/DHLA M147 MANIFOLD CORONA 1600 2 X HS4 SU M148 MANIF COROLLA 2 X HS4 SU M198 MANIFOLD CELICA 1600 1 X DCOE/DHLA M199 MANIF CELICA 18R 2000 1 X DCOE/DHLA Not a very informative webpage! Some engine designations would be useful. As far as I know Lynx don't make SU manifolds for the K engine any more, so there will be no new ones again. Quote
philbey Posted August 15, 2011 Report Posted August 15, 2011 Waste of time trying. Weber/Dellorto manifolds are 4 to 4 ports. SU manifolds are 4-2 ports. Adapting 4 SU's will be a nghtmare. If you're that stuck either go for Weber/Dell setup (one for sale at the minute, 150 per carb+170 for manifold = 470 bucks which is a reasonable price) Or hand make your own SU manifold. Quote
Rollerin Posted August 15, 2011 Author Report Posted August 15, 2011 Mine have the swivel fuel bowls, and i thought it would be interesting to try but i might just find the right manifold :) Quote
Redwarf Posted August 15, 2011 Report Posted August 15, 2011 I will definitively answer this question for you. No. Quote
tojo2 Posted August 15, 2011 Report Posted August 15, 2011 I can't find su manifolds for a 3k any where, give me link if you do. http://www.rollaclub.com/board/topic/50486-su-manifold/page__p__516270__hl__su__fromsearch__1#entry516270 haggeling on $100 :no2: You sure you want some? :rolls: Quote
philbey Posted August 15, 2011 Report Posted August 15, 2011 Wow that is funny as. Dude these manifolds do not come up often. Pay the man his 100 bucks and be done with it. Trust me,I looked for a long long time. Quote
ke70dave Posted August 15, 2011 Report Posted August 15, 2011 haha now thats lowballing! i think this is one of those, 'suck it up' scenarios. i never knew that about the SU's needing to be on an angle in order to make the fuel bowl vertical. makes sense though. Quote
