VOLK Posted August 1, 2011 Report Posted August 1, 2011 (edited) Hey dudes, bit of a read but please don't vague out half way through and close the tab hehehe :P Just purchased a project which will eventually become my other half's car. AE92 auto w/4AFC, 268 thou on the clock & with what I suspect is a blown head gasket :( Oil floating in the coolant, but no coolant in the sump? I was always under the impression that when a head gasket allowed two galleries to mingle that everything got everywhere? Can anyone confirm this? Weird thing is, the car still runs fine, just was low on coolant when I picked it up. The header tank was basically empty besides oily brown sludge, opened the radiator cap and found more of the same. Filled both up and it drove ok. Didn't overheat, if anything it lost and gained temp most likely due to lack of thermostat. Sound about right? Now I'm no stranger to spanners but I've never done a head gasket before. This is my 1st Toyota so thought it best I join the hallowed members of Toyotadom on this fine site and hopefully pick some brains, mebbe get some help from the local gurus?! I'll also be grabbing a manual online but I just wanted some tips from those who've done it. I've found a VRS kit on UK eBay here. Is this all I'll need when doing a head gasket? Timing belt was done at 230 thou apparently so that should still be ok. What else should I do with the head off? Water pump? Any other seals? Will I just need the head rebuilt/skimmed etc but the block should be fine to accept a new gasket? If I was supposed to chuck up a member's ride or intro post first, my apologies and I'll take care of it asap. I searched around and didn't spot obligatory requirement for either. Also searched for info about 4AFC head gaskets and didn't find anything definitive like a guide. So... Proof I'm no stranger to mechanical frustration and because I know you all love pics: Edited August 1, 2011 by VOLK Quote
GJM85 Posted August 1, 2011 Report Posted August 1, 2011 Get the manual and follow it to the 'T'. The 4a-fc has slave cam design where the inlet camshaft is geared off the exuast camshaft. The timing belt only drives the exaust cam and the waterpump. The distributor runs directly out of the exaust cam aswell. It's a bastard of an engine. If you can manage to get the inlet manifold and carby off your doing great. The narrow valve angle A series engine is actually a far more complicated engine then other wide angle twin cam engines. Quote
VOLK Posted August 1, 2011 Author Report Posted August 1, 2011 After the Legnum it looks fairly easy to get into. Fair bit of space & low complexity. I say that now but I'm sure my opinion will change once work has begun :D Thanks for the info. Best be acquiring a timing light I think. I'll get it to TDC on number 1 and start pulling things apart. That vrs kit on uk eBay the best source? Anything else I should do whilst doing the head? Ex-mechanic at work said crack open the sump and unbolt the rods, set of new rings. Don't think I wanna invest that much time or money! Quote
VOLK Posted August 11, 2011 Author Report Posted August 11, 2011 Has anybody purchased a vrs kit for the 4afc from eBay? I've found a few that just state 4AF & 4AFE, do they use the same head gasket? I'd imagine the kit would just have different manifold gaskets due to 4afe being EFI? These guys say it won't fit the 4AFC http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=160437180272 And these guys say they only have a listing for the Holden Nova http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=170649062841 which is essentially the exact same car and I'm assuming no engine or drivetrain differences between the two? Quote
AE92-4AFC Posted August 15, 2011 Report Posted August 15, 2011 How much are you looking at spending. Considering most wreckers have 4a-fc's and more to spare. It might be worth taking parts of a donor car Quote
VOLK Posted August 16, 2011 Author Report Posted August 16, 2011 $500 max. This should cover all parts and head work. Mate of mine is a mechanic so the labour's free. Reckon I could do better with parts from a wrecker? Quote
ke70dave Posted August 16, 2011 Report Posted August 16, 2011 all depends on the condition of the head when you take it off. if you pull it off and find its all in good condition, an acid dip, a quick skim 500 should cover it. if you need a few new valves, more than a skim, if there is any corrosion, the price may blow out. Quote
VOLK Posted August 16, 2011 Author Report Posted August 16, 2011 VRS kit & head bolts should come in under $250. Quoted another $250 for head work (skim, replace valve stem seals etc.) from south side cylinder heads. Hoping no surprises come up :hmm: Quote
AE92-4AFC Posted August 18, 2011 Report Posted August 18, 2011 well i have a complete ae92 for $1200 if youd like the thing runs and only just ran out of rego, i know its a little more than budgeted but its a complete car with no parts missing. Quote
VOLK Posted August 18, 2011 Author Report Posted August 18, 2011 I'll pass thanks man. Will be able to fix everything for a little over $400. Quote
AE92-4AFC Posted August 22, 2011 Report Posted August 22, 2011 sweet. i love it when cars get fixed for less then you hoped haha, got my clutch done including parts for $500 Quote
VOLK Posted August 22, 2011 Author Report Posted August 22, 2011 Bargain! Ah well, at least I've got one car that's cheap to fix. Legnum's going in for 100thou service @ ~$1700 :( Clutch is an epic job too that I'm not expecting change outta $1500 0_0 Performance comes with a price. I've been driving the corolla more than the legnum lately too, so much easier on fuel! Quote
AE92-4AFC Posted August 25, 2011 Report Posted August 25, 2011 Yeah that's one reason I love the rollas is fuel economy. Still though can't wait to get a 4AGZE Quote
smaccas1411 Posted July 9, 2016 Report Posted July 9, 2016 Cheap as just do it yourself. Make sure you get the full gasket kit because if the head gasket is gone the others will be poked or they will be once you pull it to bits. Just make sure you get it clean as and you may as well clean out all that carbon buildup while you have her town down. Quote
