Hey guys...
I'm currently wiring up my 4age conversion into my ke70...
I have extended the positive and negative wires onto the opposite side as the dizzy is on that side...
my problem is that when I put a test light on them and turn the ignition on i get no light turning on... hmmmm
Is there a possibility that the ignition relay or fuse is broken? or i currently have my dash out.. could there be a connection in the wiring loom/harness that is disconnected at present?
Any help would be appreciated!
Cheers
Could be a lot of things... Welcome to the world of engine conversions!
Do you have a wiring diagram of both cars? The whole AE86 workshop manual is up on the web, and I found the KE70 wiring diagram up there somewhere too. I have them lying around I think.
Once you have both you can figure out where they join up, which won't be too bad if the 4AGE is still on carbs
