lukemo1982 Posted July 22, 2011 Report Posted July 22, 2011 can someone plz help my 3k ke30 will not idle even after its warmed up and while crusin round 30kph in 3rd gear the car shutters but doesnt do it all the time :bash: Quote
ke20rolla Posted July 22, 2011 Report Posted July 22, 2011 Make sure your timing is correct first, then I'd be checking if it's getting enough fuel to the carby and also some of them have a fuel cut off solenoid which plugs into a connector just next to the carby on the inner guard. If this wire is not connected it wont idle. :happy: Quote
altezzaclub Posted July 22, 2011 Report Posted July 22, 2011 Idle circuit gone- Dirty idle jet, or as ke20 says, the idle shutoff solenoid if you have one fitted. I thought they came out on the later models like the KE70. The idle jet runs the car up to a couple of thousand pm before it hands over to the man jet completely. Quote
lukemo1982 Posted July 26, 2011 Author Report Posted July 26, 2011 it ended up bein a split o ring in the carby runs like a dream now! thanks Quote
