eefui Posted July 20, 2011 Report Posted July 20, 2011 04. This is a 4 speeds gearbox, planing changing a 5 speeds gear box 05. clutch 06. fly wheel 08. 8 valve OHV engine 09. water pump spoiled。 10. valve rod spoil 11. stick 12. gasket burned 16. Timing too long. 19. oil ring jam. 23. cleaning (DIY) 25. spray to black colour 26. polishing 28. Head cover polished 29. New Piston 30. Overside Piston. Quote
eefui Posted July 20, 2011 Author Report Posted July 20, 2011 31. lighted flywheel. 33. crankshaft with modify 37. new timing chain, this one is double chain, if 5K, only single chain 39. Bearing shell 40. 42. piston ring 44. new gasket 45. valve modified 48. special modify, piston is more high over the block about 0.3mm, increase compression 49. new timing chain 50. cam shaft 51. 3K engine 52. oil steal 54. new water pump 55. oil pump Quote
eefui Posted July 20, 2011 Author Report Posted July 20, 2011 65. engine room painted 68. install air-con fan 75. upgrade battery 76. 5speed gearbox. 77. Second hand Sport Rim, W:6.5inch, 15inch, PHB:114.3mm, offset: 20mm . 78. Tyre 185/60 R15 Quote
Clapped out Posted July 21, 2011 Report Posted July 21, 2011 you've done a great job there mate! :y: Quote
altezzaclub Posted July 21, 2011 Report Posted July 21, 2011 Nice work! It will surprise a few other people when you drive beside them! Quote
