Just wondering what would be the price for a 4k flywheel???
reason i ask is , just wanting to get a ball park figure so i don't get ripped off?
also what model engine are compatible (with my 4k) can i get fly wheel from 5k ,7k???
Edited by newjak
3k or 4k fly wheel is all you can use. Most 5k flywheels have a 210mm clutch face as opposed to the 180mm of the 3/4k's.
They should be relatively cheap. The price you pay will be directly influenced by availability and how bad you need one.
if you pay more than $20 your getting ripped off. $10 is a good price, $0 is even better.
you need a 3/4k flywheel. they shouldnt be hard to find
theres pros & cons with that^^
one con I'm having now is belts wont stop squeeling cause the engine is revving so quickly that the alternator can't keep up!
also smooth idle is a issue and can't take off slowly just with the clutch or youll stall
but f@$k me does it love to rev!
thanks for the replies guys!
f@%ck me , i rang a wreckers in campbelltown and he wanted $180 for a flywheel and bolts....highway robbery i says...heheheh
now the search continues last piece of the puzzle for my conversion
that obviously came with a 4k or a ke70 with a 4k in it yes? :huh:
5k is 200mm ;)
Good grief Evan, how much did you take off?
Get an aerosol of CRC Beltgrip and spray it on the fanbelt. It works well.
tried that. tried another belt aswell. works for a couple days and squeeel like a pig.
enough said? :P
far out, take any more off that flywheel and it will become transparent!
and yes, any 2nd hand standard 4k part should be free or under $20.
you can buy an entire 4k engine with a 4speed for under 150 usually!
what did that flywheel end up weighing?
the belt shouldnt squeel anyway, alot of motors rev faster without an issue, considered issues with alternator?
