punchy111 Posted July 9, 2011 Report Posted July 9, 2011 Hey, Ok, my car has been a bit jumpy etc and i thoguht it may be the fuel filter and/or the fuel lines. so i changed both thisafternoon and it wont start. the arrow is in the right direction and I'm sure futl is coming through. does anyone have any idea how i can fix this?? Quote
GJM85 Posted July 9, 2011 Report Posted July 9, 2011 On 7/9/2011 at 8:54 AM, punchy111 said: Hey, Ok, my car has been a bit jumpy etc and i thoguht it may be the fuel filter and/or the fuel lines. so i changed both thisafternoon and it wont start. the arrow is in the right direction and I'm sure futl is coming through. does anyone have any idea how i can fix this?? Check your getting spark by removing your plugs and testing them against the block while turning the engine over. It could be a timing or fuelling issue. Check you dizzy cap for corrosion and the points can sometimes weld themselves shut so you may have to reset the gap or get new ones. Quote
