Decided it's time to tackle the whole zero power issue to the car.
From what I can tell with the wiring diagram, I have blown a fusible link in the circuit, resulting in the whole no power thing..
How do I replace these? Also, will I need to replace the wiring throughout the whole circuit as well?
Not a wiring expert, just want to know my options, other than "take to auto elec". Currently flat broke..
Thanks, Sam
  • 2 months later...
check for voltage before the link and after. if voltage there before fuse and not after its kaput.
you should be able to replace it. if you can't just cut it out. solder some terminals to the ends of each wire and plug in a new fuse
