parrot Posted June 10, 2011 Report Posted June 10, 2011 (edited) A while back I proposed posting up a file of gaskets people could copy onto gasket paper or cork as applicable. Nothing seems to have happened with it, so I will put these up here. If applicable, mods may wish to relocate. I will add to it as I can. For example, I have an earlier T50 set somewhere too. Presumably since they are attached as pdf files, they should print out as actual size. Please feel free to add stuff you may have, but probably best not to clutter the thread with chat. KE1x Gearbox overhaul KE1x water pump and axle flange.pdf KE2x gearbox gaskets.pdf AE86 T50 gaskets.pdf Edited January 1, 2021 by parrot Quote
parrot Posted June 28, 2011 Author Report Posted June 28, 2011 (edited) And here are the Early T50 gaskets to go behind T engines Early T50 gaskets.pdf Edited June 28, 2011 by parrot Quote
philbey Posted June 29, 2011 Report Posted June 29, 2011 Parrot, apologies, you sent me these some time back but I never replied. A minor update though, I've got access to a laser cutter and I'm still keen to collect a library of gaskets. I've got a full 3T-GTE gasket kit ready to go onto the scanner this weekend, and they are nigh on impossible to get parts for. Anyone else with Gaskets they can ID, please go ahead and scan and post them. Put a ruler on the scanner as well to calibrate against. Quote
parrot Posted June 29, 2011 Author Report Posted June 29, 2011 No worries, I mean it's not as if you haven't got anything else to do besides devoting your spare time to this site! As I said, I presume that being pdf files, these will print out actual size. If you need them redone with a ruler, let me know. Quote
philbey Posted July 7, 2011 Report Posted July 7, 2011 Yeh that's all good PDF's should be fine, it's more the JPEGS that could be a problem Quote
parrot Posted August 8, 2011 Author Report Posted August 8, 2011 These are the paper gaskets from the 2TG full engine set, with the exception of the inlet manifold gasket which I have lent out. I'll put this up when I have it. 2TG paper gaskets.pdf Quote
TE278U Posted August 8, 2011 Report Posted August 8, 2011 legend ;) worked a treat, and i got my replacements today. i will see you at donuts if not before. :D Quote
parrot Posted August 24, 2011 Author Report Posted August 24, 2011 2TG inlet manifold gasket. MAKE SURE YOU PRINT IT IN A3 OR IT WILL BE TOO SMALL 2TG inlet manifold.pdf Quote
SLO-030 Posted September 5, 2011 Report Posted September 5, 2011 Anyone want xK-B inlet mani gaskets? Quote
SLO-030 Posted September 5, 2011 Report Posted September 5, 2011 (edited) I'm hoping to hear back from a supplier of mine. Should be able to get a heap in. Figured it would make it easier for them to be ready done than having to find a place to make em. Edited September 5, 2011 by SLO-030 Quote
Mitch-12 Posted September 5, 2011 Report Posted September 5, 2011 anyone know where to gey k40 gaskets? Quote
parrot Posted October 15, 2013 Author Report Posted October 15, 2013 Some new additions: As before print in A4 size 4AGE Bigport throttle body and ICSV valve gaskets. 4AGE throttlebody.pdf Also what I believe is an S series diff gasket. I ordered a T series one from Toyota but they stuffed it up S series diff.pdf I should have some T series diff gaskets soonish thanks to Amayama and I will add these when they arrive. Quote
