Mitch-12 Posted November 24, 2011 Author Report Posted November 24, 2011 that fj is gonna be sick haha um that dizzy looks the same if take the tin cover thing off and take a pic of the hall/optical sensor thing i can tell you if it will work then Quote
Mitch-12 Posted November 26, 2011 Author Report Posted November 26, 2011 so today i picked up some parts from bursons still need to get my king's springs and my slotted rotors monday but i got my drums,pads,shoes and clutch and my water cooled brakes I'm working on just gotta work out something for the rear and i gotta put a washer bottle in my car Quote
kickn5k Posted November 26, 2011 Report Posted November 26, 2011 Hey mitch don`t the race trucks run something similar water cooling wise? like the idea, can see it now under brakes at the end of the straight steam pouring out!! :yes: Quote
Mitch-12 Posted November 26, 2011 Author Report Posted November 26, 2011 haha yeah i kinda dreamed up the idea from the race trucks they have steam pouring out under brakes haha Quote
Mitch-12 Posted November 26, 2011 Author Report Posted November 26, 2011 can i spray water inside the drum on the rear? Quote
carbonboy Posted November 27, 2011 Report Posted November 27, 2011 Wouldn't that reduce the amount of friction (therefore stopping power) the shoes have on the inside of the drum? On the outside should suffice to reduce the heat buildup? Quote
irokin Posted November 27, 2011 Report Posted November 27, 2011 My understanding of water cooling brake rotors is that the water is actually sprayed into the vanes of the rotor, not on the face. I suspect when you're spraying water onto the working surface of the rotor you'll end up with all kinds of drama concerning the pad material laid down on the rotor which is absolutely necessary for good pads to function effectively. Not to mention the potential problems with shock cooling when the surface is over 600 degrees. I'm guessing you still have solid rotors? If that's the case then the solution, to my mind, is to upgrade the brakes to something at the very least vented. Then if you still have problems start spraying the inside of the rotor vanes. Quote
abbott Posted November 27, 2011 Report Posted November 27, 2011 he did mention he's getting slotted rotors :P Quote
Mitch-12 Posted November 27, 2011 Author Report Posted November 27, 2011 (edited) yeah i have solids haha and the rear sprays on the outside and the brakes are stock so i don't want them to get hot :)and only bendix general pads and the water sprays when the brake lights are activated and the water stays on for 3 seconds after the brakes come off just like our supercars Edited November 27, 2011 by mitch-12 Quote
Mitch-12 Posted November 27, 2011 Author Report Posted November 27, 2011 (edited) My understanding of water cooling brake rotors is that the water is actually sprayed into the vanes of the rotor, not on the face. I suspect when you're spraying water onto the working surface of the rotor you'll end up with all kinds of drama concerning the pad material laid down on the rotor which is absolutely necessary for good pads to function effectively. Not to mention the potential problems with shock cooling when the surface is over 600 degrees. I'm guessing you still have solid rotors? If that's the case then the solution, to my mind, is to upgrade the brakes to something at the very least vented. Then if you still have problems start spraying the inside of the rotor vanes. our supercar and every other supercar and our race truck has them and they spray in the ducts and all over the caliper and rotor and they work good i wouldnt do it if i didnt know it worked... Edited November 27, 2011 by mitch-12 Quote
Mitch-12 Posted November 27, 2011 Author Report Posted November 27, 2011 i have my rear brakes done :)and water squirters hooked up :) just need to put my front slotted rotors on after i get them monday and my king springs.. and a few little jobs to do Quote
Mitch-12 Posted November 27, 2011 Author Report Posted November 27, 2011 ringing up tommorow to get it booked in for a rollcage before australia day :) so i will be safe Quote
Mitch-12 Posted November 29, 2011 Author Report Posted November 29, 2011 Car is going to canberra to get the rollcage done on sunday so will be there for a while getting the cage done and its going to be tig welded woo :D Quote
SLO-030 Posted December 1, 2011 Report Posted December 1, 2011 i have my rear brakes done :)and water squirters hooked up :) just need to put my front slotted rotors on after i get them monday and my king springs.. and a few little jobs to do Slotted or vented? Quote
Mitch-12 Posted December 1, 2011 Author Report Posted December 1, 2011 Slotted or vented? slotted :) still solid though Quote
