HP Racing Posted July 23, 2011 Report Posted July 23, 2011 Man that is a "fully sick ke-70" dash!! Lol. Nice work, can the dash be reconfigured for more rpm on the tach? So I spose all you need is the engine loom and it would fire up? Stu. was playing with it just before and rpm goes to 32 000 it goes to 2 digit numbers on the bar graph so enough revs for anything Quote
kickn5k Posted July 24, 2011 Report Posted July 24, 2011 was playing with it just before and rpm goes to 32 000 it goes to 2 digit numbers on the bar graph so enough revs for anything Wow 32000rpm. Only things I know that spin that hard are the little nitro RC engines. I wanna see it running, and some numbers from the dyno. Stu. Quote
carbonboy Posted July 24, 2011 Report Posted July 24, 2011 I wanna see it running, and some numbers from the dyno. +1 !!! :yes: Quote
HP Racing Posted July 24, 2011 Report Posted July 24, 2011 might not be running on E85 for its first few events cause i don't have any and when we need it next i get it cheaper instead of buying just for this but we have plenty of avgas :) don't need that much power and i want it to last so ill give it as much timing as it will take then pull a few degrees out and richen it up a bit but when i get my E85 in it ill see what it can do then :) gotta remember the engine is 100% stock inside only has a new HG cause it was blown from boiling so often haha i don't stop if water boils if i lose oil press i think about it a bit haha Quote
Mitch-12 Posted July 25, 2011 Author Report Posted July 25, 2011 (edited) First race date set 28 September should be a big day with 30+ people and hoping i can win, few rally cars coming but can only run radials and with my no rules i rekon i can back myself to win against similar car with rally rules so see how i go after the 28th got some work to do :) (28 of august not september) Edited July 30, 2011 by mitch-12 Quote
Mitch-12 Posted July 30, 2011 Author Report Posted July 30, 2011 Got some done today only took two pics i have fuel pressure now woohoo and incar loom is finished also started on engine loom Returnless fuel system ecu to firewall loom i have 3 more weekends before its time to race so should be going in that time easy Quote
jimi91 Posted July 31, 2011 Report Posted July 31, 2011 i have 3 more weekends before its time to race so should be going in that time easy Famous last words lol :lolcry: Looks good as mate and I'm sure will be one sweet racer when its done :happy: See ya Jimi Quote
Mitch-12 Posted July 31, 2011 Author Report Posted July 31, 2011 haha i have faith I'm uploading pics now the ecu talks to the dizzy so i know it will run and has spark woohoo Quote
Mitch-12 Posted July 31, 2011 Author Report Posted July 31, 2011 Also I'm redoing my front end i have better ideas since i built it last time should be good Quote
Mitch-12 Posted July 31, 2011 Author Report Posted July 31, 2011 i only used it on the plate for the bosch bov on the supercharger pipe everywhere else i would rather have gaskets or 515/518 if it is a flat surface Quote
jimi91 Posted August 1, 2011 Report Posted August 1, 2011 Hahhaha yep :wink: Looks good as bro keep it up :happy: See ya Jimi Quote
Spencer[RL] Posted August 1, 2011 Report Posted August 1, 2011 Do you have a tension pulley between the Sc and the crank pulley? Quote
Mitch-12 Posted August 1, 2011 Author Report Posted August 1, 2011 Do you have a tension pulley between the Sc and the crank pulley? no tension pulley still need to make a top bracket for the sc and a plate on the pulley to keep the belt aligned Also got the engine loom finished just needs injector plugs and i have spark woohoo :D and everything else works perfectly Quote
