ke70dave Posted June 6, 2011 Report Posted June 6, 2011 yep, but you need ae86 steering arms as well. Quote
redae71 Posted June 10, 2011 Report Posted June 10, 2011 you don't need ae86 steering arms! my gold 70 is running custom coilovers made from 86 struts and using std ke tie rods and ends.... aligned easy and plenty of thread to go..... also usin d2 ae86 camber tops Quote
rian Posted June 10, 2011 Report Posted June 10, 2011 (edited) you don't need ae86 steering arms! my gold 70 is running custom coilovers made from 86 struts and using std ke tie rods and ends.... aligned easy and plenty of thread to go..... also usin d2 ae86 camber tops You definitely do need ae86 steering arms, ke70 steering arms will not fit onto ae86 struts. You can use ae86 strut tops but they will alter your caster, ke70 strut tops are a better option, especially if they're already in your car. Camber tops from an ae86 will fit but I'm not sure what the go is there regarding caster. Redae71 are you getting confused with control arms or something? I know you know your stuff but I don't know what you're on about? Edited June 10, 2011 by rianwest 1 Quote
cerby Posted June 11, 2011 Report Posted June 11, 2011 just chipping in on the steering arm debate. ke70 struts 100% do not fit ae86 steering arms and vice versa. Quote
