I've seen the TRD brothers do a box and a clutch in the middle of a paddock in under 20 minutes.
Being your first attempt, it may take a little longer.
Just my 2c;
I'd keep the 4spd in it; unless your doing highway driving all the time or have some sort of high powered 4k(?)
I used to have a 5spd thinking it was better cos more gears; that's how it works right? lol
Then the 5spd cacked itself and i needed a gearbox quick, picked up a 4spd and it was so much nicer to drive.
Realised i didn't really need 5th gear and was more hassel than anything else.
Anyway gl with the gearbox swap; those things are light as in a ke70!
First 4 gear ratios are the same except in the early boxes, 5th is just a higher gear tacked on the end of a KE70 4speed.
You're right, we never use 5th around town, 4th is just fine- but 5th is handy at 100kph, that 300rpm drop makes the car a bit more civilised.
Yeh I drive about 15 mins to work every morning and sit on 100ks 90% of the way so 5th gear would be heaps better for me
I very rarely drive through the city or in traffic because of my work hours I avoid most the traffic
Ahh rightio, i had myself an early gearbox; preferred it for driving to work through the hills every day. Felt like a rally car!
well i swapped from a 4 speed to a speed by myself in jus tover 1 and 1/2 hours and that included stopping for a drink and a sanga cause I'm cool like that haha nah man easy job u in brisbane area can swing round and give u a hand
i personaly have never had the clutch plate problem don't know if anyone else has I'm not saying its a mith just saying from my time mucking with rollas havent been stung with a clutch problem
