hi guys
i'm wondering if some one could help me out i've just finished
installing xt130 struts and brakes on my ke30 everything fitted well
but when i put my wheels on the drivers side sat ok but the passenger
side wheel is sticking out a bit it looks like it has a bit of positive
camber i am using the steering arms of the xt130 and both wheels ar the same
so i'm unsure whats going on hope some one will be able to help me thanks
  On 5/29/2011 at 8:05 AM, nesta said:
hi guys
bent strut?
  On 5/29/2011 at 8:13 AM, Crowie55 said:
bent strut?
i hope not but .i also for got to say that was with my mags and if i put the standard xt130 wheel on it seems to sit ok
  On 5/29/2011 at 8:15 AM, BlueKsev said:
The wheel jammed against the rotor or caliper? I know the standard 13s wont fit over the xt130 front end.
well in that case Blueksev is on the money
mm the wheel spins ok with no noise doesnt seem to be hiting the caliper took it for a drive and all worked ok
