pipster11 Posted May 27, 2011 Report Posted May 27, 2011 so my ae93 gti had a leaking welsh plug just removed it and i'm deciding to replace the others at the front of the motor too should i do it while i'm there or just leave them? they don't look corroded at all but should i replace them or not? Quote
ke70dave Posted May 27, 2011 Report Posted May 27, 2011 in my opinion if they aren't broken don't fix them! just make sure you check them out make sure they aren't leaking or aren't corroded etc. give them a good clean so you can see them properly etc. Quote
corollaart Posted May 27, 2011 Report Posted May 27, 2011 If your already there do them all,if ones gone chances are they are nearly all due to be done.Just because they look alright on the out side accounts for nothing. The engine may have been run for years with out coolant hence corosion etc rob Quote
pipster11 Posted June 2, 2011 Author Report Posted June 2, 2011 yeah i was tossing it up but ended up leaving them the car only has to last a couple of years and i've got another car so it can be off the road again would have like to do them all but i couldn't be bothered at the time Quote
